what cam
  • Thread starter Thread starter DURRETT
  • Start date Start date Jan 29, 2008
D
DURRETT
18
  • Jan 29, 2008
i got a stock bottom end i just got a new set of afr heads 165cc and a holley systemax intake,but i dont know what cam to go with i have heard that i cant use to big of a cam some say i can use whatever cam i want,some say i need a custum cam i would like to use a f cam or maybe a voodoo can someone please help this is my first bid i want to make as little mistakes as i can oh i will be driving this car on the street
ttop88
42
indiana
Jan 29, 2008
  • Jan 29, 2008
http://www.andersonfordmotorsport.com/
87foxstang
Cromwell, CT
Jan 29, 2008
  • Jan 29, 2008
F cam is ok, but there are way better out there. I have a voodoo cam and love it. Although its for a SD car so its not to aggressive
PUNISHER RACING
1,124
FORD CITY, PA.
Jan 29, 2008
  • Jan 29, 2008
Its cheap and it works great.................................. Motorsport X !!!!!!!!!!!
D
DURRETT
18
  • Jan 29, 2008
so the ford motorspaorts x cam or voodo and i will not have to worry a valve clearence what cam will give me the best sound
68converted
772
Colorado
Jan 29, 2008
  • Jan 29, 2008
I went through this same question when I did mine. I ended up with the Comp Cams xtreme energy 270. From what I was able to find from all the import is that the cam would give me nice balance of go with driveability. Unfortunately I have not started the car up, but I am looking at 2 wks until startup.
Not sure when you are looking to purchase but I can IM you when it is running.
Oh sorry, I have the AFR 165's, 70 mm TB, 73 mm Mass Air, Edlebrock RPM 2, 270 XE cam, 1.6 RR's, stock bottom end. The intake is most likely going to be too much, but I will figure that out once it is running.
9
91notchbk
163
Jackson Michigan
Jan 30, 2008
  • Jan 30, 2008
I agree with 68converted. I have the XE270HR14 and really like the full range of power. I am impressed with Comp and their line of cams. I have AFR165s as well. See my sig for my combo.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 30, 2008
  • Jan 30, 2008
Go with Ed Curtis @ www.flowtechinduction.com.
He sells AFR heads and the Holley intake that you have. He can set you up with a CUSTOM camshaft and the springs to match
Shoot him an email He will get back with you...
Make sure he knows that you are wanting to purchase from him, and not just trying to get information.
9
91notchbk
163
Jackson Michigan
Feb 1, 2008
  • Feb 1, 2008
XE270hr14 Comp cam. Very nice cam with a very wide range of power.
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
