With the stock intake design, both the Stage 1's and Stage 2's tend to yield close to the same hp results. Now, if you have an aftermarket intake like the one from Fox Lake, then definately go with the stage 2's as they will result a higher net gain in power. Also, as stated above....if you plan on going with Stage II's, be prepared to upgrade to aftermarket springs.
