What Carb should i go with?
  • Thread starter Thread starter nitequill
  • Start date Start date Dec 22, 2006
N
nitequill
45
Los Angeles
Dec 22, 2006
  • Dec 22, 2006
Hey guys im rebuilding a 73" 351W, it came with a 2 barrow carg and manifold... i just bought a edelbrock performar intake but im not sure whats the best carb to go with for my build up. its going to be used as an daily driver but i want to be able to go to the track every now and again as well... i want to go with the 600 cfm edelbrock but im not to sharp when it comes to carb talk...
bnickel
5,640
lubbock, texas
Dec 22, 2006
  • Dec 22, 2006
for a DD with a basically stock engine the performer 600 is a good carb. very dependable and works great right of the box.
Max Power
1,774
St Paul
Dec 22, 2006
  • Dec 22, 2006
With a Performer intake and stock heads, a 600cfm carb is all you need.
N
nitequill
45
Los Angeles
Dec 26, 2006
  • Dec 26, 2006
Thanks guys
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Dec 26, 2006
  • Dec 26, 2006
Everybody is correct but I wanted to add that the "Performer" intake is basically a direct replacement for the stock intake. just made of aluminum instead of cast iron. It really doesn't offer any performance. The RPM, Weiand stealth, or better yet the RPM Air Gap would offer some more giddyup.
I just mention this because any gain you get will be solely from the carb. upgrade. If you can swap the intake for a better one, then you will get a slight gain and be ready for further upgrades (heads and cam). Also, if you go with one of these intakes, a "slightly" larger carb. may work better.
Z06killinSBF
457
McKinney, TX
Dec 26, 2006
  • Dec 26, 2006
Yes on the 600 Edelbrock, may even try like a 525 or something. That motor only has 8.5:1 comp so you don't need much. Also, if you go with the Edel carb, get the electric choke model as it runs a little leaner.
N
Netsbetterhalf
Tacoma, Washington
Dec 26, 2006
  • Dec 26, 2006
I agree w/ mustangdave on the performer vs. RPM Air Gap. Unless you upgrade your cam the 600 is plenty but changing your manifold will help w/ the giddy-up factor. Edelbrock does offer packages that include cam, carb, manifold. Look at their website for suggestions.
C
Bored with my 73
  • Curtis Harper
  • Apr 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 23, 2026
RaggedGT
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
