What carburetor and intake should i choose when switching from a 2bbl to a 4bbl?
i would recomend either the performer rpm or the weiand stealth intakes, your pick both are good. for a carb, if the engine is under 320 ci, and making less than 400 hp stick with a 500 cfm carb, the edelbrock and the road demon are good ones. if you have an engine over 320 ci, or making more than 400 hp then step up to a 600 cfm carb, again the edelbrock or road demon carbs are good ones.
You also can't beat the factory's old setup---- which consists of one of the following intakes ( these are all the same intakes, just different names/brands) the old "Cobra" high rise dual plane , the old Ford C9OX or the current FMS A321 and Edelbrock's old F4B. Any of these with a Holley 600 cfm ( vac. secondary) will get you what you want. If you have a 4 speed car, and you're contemplating more mods later, you might also consider a 600 cfm double pumper
