What causes a rear main seal leak?
bloopbloob
578
Alberta
I was just under my car today, and noticed a bit of oil. it was getting dark, but i'm thinking its the rear main. I've had the rear main seal replaced once before, then once again 2 days later because it blew out (bad install, which was coverered by warranty). now i think its leaking again, but its a slow leak compared to the 2 geysers i had to deal with before.... so why is this happening?
Yep, as far as causes that are easy to check/fix, ensuring the crankcase ventillation is adequate (like 88Mouse said) is important. If the pressure bottlenecks, it goes for the path of next-least resistance, which is often the RMS.
Good luck.
