what changed ??!!!??
  • Thread starter Thread starter thenewguy65
  • Start date Start date Aug 21, 2006
T
thenewguy65
53
  • Aug 21, 2006
I changed my intake, rebuilt my carb, got it running. Took it for a test drive and it ran ok...not great but ok. Two-three days go by and I change my valve covers and pcv valve yesterday.
I start my car and it runs for 4-5 seconds and then dies. My wife notices a little light smoke behind the car. By the time I turned around I couldn't see any. And now it won't start. It seems like the timing was thrown off but the dizzy was locked down.
I will check for a new vacuum leak but I'd be surprised if one crept up. This is pretty damn frustrating.
M
mustangman70
1,235
St pete, Florida
Aug 21, 2006
  • Aug 21, 2006
Did you use a gasket between the carb and the intake?
T
thenewguy65
53
  • Aug 21, 2006
I am running a cast iron 4 barrel intake, a spacer plate with a gasket above it and below it. I can't see how changing the valve covers would affect anything. I will double check things tonight. It's just really frustrating. I'd hate to have to pull all this stuff off again and start all over.
Setting the timing has been the biggest #$@!# for me because I am still learning how to do it. I don't have a timing light.
hhead
280
so cal
Aug 21, 2006
  • Aug 21, 2006
I wouldn't doubt the dist moved a little.. If you loosen it and turn it a little, will the car start. Even w/o a light you should still be able to get it running.
Are you sure you have gas? (not trying to be funny)
T
thenewguy65
53
  • Aug 21, 2006
She's definitely gassed up. I will have to check the distributor. See if I can turn it a little in one direction or the other. I had a friend help me get it started, unfortunately he's not available for a while because of work.
hhead
280
so cal
Aug 21, 2006
  • Aug 21, 2006
If you're by yourself, you can always turn the key on and jumper the solenoid.
T
thenewguy65
53
  • Aug 21, 2006
Well I got it to start. It idles rough as hell and there's definitely light gray or light light blue (I can't really tell) coming out of the tail pipe. That wasn't there when I had the two barrel on it.
I am starting to think I have a vacuum leak. I can turn the idle air mixture screws and I get no response from the engine. I stuck a vacuum gauge on it though and I am getting 18 with no fluctuation.
hhead
280
so cal
Aug 21, 2006
  • Aug 21, 2006
okay. next, you had to remove the distributor to do the intake, correct. I think you might be off a tooth or so. it's very easy, when reinstalling. even though you marked the housing, the teeth and rotor may turn while reinstalling.
T
thenewguy65
53
  • Aug 21, 2006
Would that explain the smoke ?
hhead
280
so cal
Aug 21, 2006
#10
  • Aug 21, 2006
  • #10
sure, too early or too late firing. that's why, when you turned the distributor it fired right up. its off a little.
check your firing order also. it's VERY easy to switch wires when reinstalling. EVEN if you changed them one at a time. It happens.
2nd Mustang
2,488
Southern California
Aug 21, 2006
#11
  • Aug 21, 2006
  • #11
When you get it running good, mark the distributor position. If you ever remove the manifold for whatever reason, you don't have to pull the distributor out, unless you have a bowtie motor in there.
T
thenewguy65
53
#12
  • Aug 22, 2006
  • #12
I got it started yesterday and it idled rough again, then it just died.
I am thinking part of the problem is the PCV system. I changed the valve covers and the pcv hose and valve. I bought the stock pcv hose and it's not fully reaching the PCV valve. It's about an inch too short. I rigged it up so I thought it would work but I am thinking that's at least part of the problem. I will swap out the valve cover on that side and the pcv valve and see what happens. It will at least eliminate it from consideration.
Max Power
1,774
St Paul
Aug 22, 2006
#13
  • Aug 22, 2006
  • #13
Or an FE motor....
6T6coupe
219
#14
  • Aug 22, 2006
  • #14
The PCV is kind of a controlled vacuum leak. It's designed to suck fumes from the crankcase. If the hose is "hosed up" you could get an uncontrolled vacuum leak that will cause the car to run poorly.
Also, some valve covers have no baffle and can allow the PCV to suck in oil (poor running and smoke). The cheap chrome ones are notorious for this, but some of the cast ones also have no baffles. If that's the case, you'll need to add a sheetmetal baffle or use a baffled grommet for the valve.
12sec67
1,301
San Diego, Ca
Aug 22, 2006
#15
  • Aug 22, 2006
  • #15
what type of carb are you running?
make sure none of the vacuum lines or vacuum plugs got blown off the carb.
T
thenewguy65
53
#16
  • Aug 22, 2006
  • #16
I have a baffle in the valve cover. I just think the job I did of getting a seal with the hoses is probably a little messed up. I am running an Autolite 4100 carb. I checked all the other vacuum fittings and they are all good.
I will know this afternoon when I put the old valve cover on there and hook up the hose for it. I need to go buy a hose to fit over the pcv valve first. I will run that to my spacer and then we will try it again.
T
thenewguy65
53
#17
  • Aug 22, 2006
  • #17
turns out, as soon as I replaced the old valve cover with the correct PCV grommet, it started up with no smoke and idled pretty good. Thanks for everyone's help.
I am still not sure if the carb I rebuilt is totally successul but I am getting there.
66moneypit
536
Northern Va
Aug 23, 2006
#18
  • Aug 23, 2006
  • #18
If you don't have a stock air filter with that setup, that might explain why that stock hose didn't fit. I think the stock hose ran to the air filter. If I remember my shop manual correctly. One ran from the pcv valve and the other ran from the spacer to the air filter.
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
