What Cylinder heads on my 91 gt?
dutchman33
I have a 91 gt pretty much stock as of now but just had a 5 lug/ disc brake conversion and I have in boxes BBK long tube headers and H pipe w/o cats and trick flow street heat intake and bbk t-body with spacer. I'm thinking I want to throw some heads in there as well, what heads will will go well with this combo...What will give me as much drivable hp as possible?:D
I would go with a nice set of trick flow heads to accompany your intake . You might also want to consider other upgrades and just do them all at once . A good set of RR's , upgrade your fuel pump and injectors , a nice cam - possibly trick flow stage 1 . Also a K&N or other CAI and a good mass air meter will give you a nice boost in HP!
AFR200
Trick Flow "fast as cast"
Canfield 195
You'll never have to buy another head for a street car like you will with a little 165 head. All of these are capable of 1.4- 1.6 HP per CID and will work on anything from a 289 to a 408.
Keep the stock cam for now or do a custom grind.
