The auto has a cast gear? What, only 5-speeds had roller motors in 85? If its the original 85 engine and its carbureted, then it has a roller cam and needs the steel gear. Easy way to check, pull out your old dizzy and see if the material looks rough and cast or smooth and machined, smooth being steel. If your really not sure then run a bronze gear since it works with both, but most likely its a steel gear.
