What do I have?
seijirou
2,417
DFW
I just bought a 69' 302 long block with 32k original miles out of a Mercury.
It's too dark for me to really read any of the numbers on it. I think the head casting numbers might be under the valve covers.
It's defanently not a boss engine, but other than that, I have no idea what I have.
Anybody care to take a shot at it?
I have a feeling I'm going to need a 28oz flywheel and balancer. And I'm going to put a new timing set on it. I want to drop this motor in my 86 to run while I build that motor. Other than those parts I'm not sure what else I might need. Bellhousing maybe?
Is this thing going to be comperable to my stock-ish late 80's 5.0, softer, or stronger?
The "Little Boss": The Boss 302 engine was introduced to Cougars late in the 1969 model year and remained available throughout 1970. The Boss 302 cranked out 290 (gross) horsepower at 5,800 RPM. This example is found in John Benoit's rare 1970 four-speed Eliminator.
I defanently do not have the boss motor. I'd recognize it immediately. I don't know how many different flavors of 69' 302 there were. If there was the boss and everything else. Or if there were several different other varieties. What was the standard 302 putting down in 69?
Produced in 1968
Cast iron crankshaft
forged rods
cast pistons
hydraulic camshaft
available with 2 or 4 barrell carburator
horsepower varied from 210 to 230 depending on carburator.
Standard 302 was equipped with 2 barrel from 1969 to 1983.
The casting number is not under the valve cover
Its on the bottom of the head near the intake side so you would have to remove the heads to get the casting number. You would know if it was a boss by the canted valves and cavernous ports. It is likely a base model 302. Does it have the stock intake manifold? If its a 4-V then it is likely a higher performance motor but I think the 2-V is exactly the same except the smaller carb and manifold.
Its not a bad year to have. The heads allow 9.5-1 compression stock and they don't have thermactor plumbing. They might have the bumbs in the exhaust port for them though but they won't have the hole for it. 69-74 302's are the better of the older ones. The mid to late 70's ones suck with their low compression-emmission heads. If you take the intake manifold off and it has "hecho in Mexico" in the lifter valley then it is a higher nickel beefier block but they are mostly found in trucks.
I guess you could get this to work in your car. Obviously you are aware of the different weight of the balancer. I think the water pump is different also. You may not be able to pass emmissions if you need to.
Keep in mind that those old motors don't have hardened exhaust seats either. Also, with an engine that old, I would re-seal the oil pan, intake manifold, valve covers, rear main, and replace the valve seals before using it. It might be low mileage, but its old and those older seals weren't made of the same materials. As a matter of fact the rear main is a two piece rope seal that is way more challenging to replace than the newer one-piece units.
So yeah, I think it would work as long as you swapped in the right fly-wheel and water pump in and put the time in to reseal it. If you have a boss engine with 32k then its probably worth twice than your car is. That would be cool though if it was.
Well like I said before. It's not a boss engine. One glance at an exhaust port removes all doubt.
This is just a long block. Nothing more than heads, block, and rotating assembly.
Because you say the water pump is going to be different am I correct in thinking then that the timing cover is also going to be different? Or can I use the late model waterpump if I'm using the late model timing cover.
That two piece rear main... Is the early 302 like the 289 where you have to have the crank machined to use the late model 1 piece main?
You also mentioned the lack of hardened exhaust seats. That sounds vaguely familiar... something like they can become a problem when using unleaded gas. Is that right?
