  • 1994 - 1995 Specific Tech
What do yall recommend(nitrous)?
  • Thread starter Thread starter hookups333
  • Start date Start date Oct 28, 2006
H
hookups333
154
Jax Florida
Oct 28, 2006
  • Oct 28, 2006
Should i do a 100 dry shot or a 150 wet shot? Im goin for safety for the engine but also the most hp. Also will my tranny die?
D
Danman765432
471
Nutley, NJ
Oct 28, 2006
  • Oct 28, 2006
it depends...and people will debate on this topic...with a wet shot it could cause puddling in your intake manifold and then it goes boom and blows your intake manifold right off...Fuel is not really meant to run through the intake which a wet kit makes it do...A better way to run a wet kit would be with a plate that sits in the middle of the upper and lower intake manifold...meanwhile with a wet kit you get more hp... dry kits seem to be the safest way but if you get a kit like the NOS kit, it measures the shots at flywheel hp instead of rwhp...i dont know anything really about how dry kits are bad for the car or none brought to my attention.
Pokageek
2,767
MA, USA
Oct 28, 2006
  • Oct 28, 2006
Dry.
blksn955.o
3,263
st.louis mo 314
Oct 28, 2006
  • Oct 28, 2006
Wet is no less dangerous than dry, with a wet all you really have to make sure of is that your not spraying below 3k rpms. There is enough vac./air being sucked in at 3k rpm to keep the fuel from puddling.
Dry will also add an extra bit of load to the inj. so if your combo is preatty healthy you may want to step up to a larger inj.
The BIGGIE with dry or wet is the rev. limit, you hit the stock rev. limit it cuts fuel...massive sudden ultra LEAN condition and BOOM for either wet or dry.
Run a window switch to turn on the n2o at 3k and off at 5,500-5,800 as long as its before the rev. limit. Make sure you have a big enough fuel pump. Remove the timing at a rate of 2* for every 50hp. Close the gap on the plugs to .35 and run one range colder plug. Lastly think about running a aftermarket ign. box for added spark to help blow out.
With the list above you will be able to run either just as saftly.
PS a 150 shot will have more power than a 100 shot...go with that
P
Pennywise2
Banned
May 16, 2006
1,379
  • Oct 28, 2006
Wet.
I would go with a Nitrous Express kit probably 75 or 100hp jets.
Best bang for the buck.
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
K
Door post and rust repair
  • Kleinjj27
  • Aug 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 8, 2026
Kleinjj27
K
