Called Comp cams today told them my specs and what i want to do and this is what they came up with...The guy doing the work said its perfect for my application what do you think?
87 gt, GT40 heads,trick flow track heat intake,1.7 cobra roller rockers,42lb injectors,255lph fuel pump,Paxton SN93 7-8 psi...UPR 4 inch powerpipe.Abaco DBX 95mm maf..
212 int. @ .050
224 exh.@ 0.50
512/512 lift...
114 center line...with a set of cobra 1.7 roller rockers
it will be 544 lift....
How do you think it will sound ? will it have any lope to it?
212 int. @ .050
224 exh.@ 0.50
512/512 lift...
..Yeah but i go to alot of cruise shows so i idle in so it would be nice to have a little lope so well you get the Idea....
