What do you think of this kit?
I'm assuming you're trying to get this linked ....
The most economical and comrehensive kit on the market! Kit includes 2 five lug front rotors. 2 five lug rear axles and drums, 2 inner and outer front wheel bearings, 2 front rotor grease seals, 2 axle bearing and seal kits, 1 bottle of friction modifier, and 3 bottles of Royal Purple 75W90 gear oil. This kit has EVERYTHING you need to convert to 5-lug the right way!
Chances are, the bullitts will not fit the front. You would be better off just doing the 94/95 spindle, hub, caliper, rotor conversion. The kit you are looking at has a very big bearing cap area, and most of the 5 lug ford rims will not be able to use the center cap because of it. I would look around on Ebay or go to your local U-pull it j/y and get the setup you need. I can get everything I need out of a junkyard here for $100 a car.
The rear will be fine though.
