I recently did the usual HCI build on my 91 vert. To me, it just doesn't have the power it should have for what I've put in it. Im hoping you all can set me straight on why it doesn't or if I'm just expecting too much. I made the following upgrades...Cold Air Intake, BBK 76mm MAF, SVE 70mm throttle body and spacer, Trick Flow Street heat upper and lower intake, Ford Racing GT40X heads, Anderson N41 cam, 1.6 Rocker Arms, BBK Shorty ceramic headers, Walbro 190LPH fuel pump, 24LB injectors MSD Billet Distributor set at 12 degrees. It has 3.73 rear gears too and mated to a T5 transmission
Honestly, It sounds terrific BUT, I can't tell much difference, power wise, from when it was stock. Im very disappointed! Ive seen videos of foxbodys with this set up breaking traction while driving in 2nd gear. Mine wont. I thought I'd see a big difference in the way it drove after the build. Am I expecting too much?
Thanks for your time!!!!
