  • SN95 4.6L Mustang Tech
What does a Bumpsteer Kit Do?
  • Thread starter Thread starter SRT Handz
  • Start date Start date Jul 15, 2005
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Jul 15, 2005
  • Jul 15, 2005
Can someone please explain what a bumpsteer kit does?
Venom_Nitrous
416
Spearfish, SD
Jul 15, 2005
  • Jul 15, 2005
Not 100% sure on this, but I believe it has to do with when you hit a bump and the tire like to "steer" or turn a little. Essentially, when you hit a bump and the suspension goes up, the front wheels like to change their toe angle. I can't think of any way to word that better. The kit eliminates that. I always thought it was a new type of steering system until someone explained it to me .
triggz
1,218
Gadsden, AL
Jul 16, 2005
  • Jul 16, 2005
It's a spherical rod bearing to help the tie-rod end on lowered cars. You'll want to get the X2 balljoints first though, that will help the most.
Look underneath the front of your [lowered] car, youll notice how the outside end of your A arms angles upward, and notice the angle of the tie rods, how they are not in line with the steering rack itself. Stock, everything is perfectly lateral.
Stay away from offset rack bushings and the bumpsteer kit until you get the X2 balljoints or something equal (you're just looking for the longer stud).
J
jjstang69
Owensboro, Ky.
Jul 16, 2005
  • Jul 16, 2005
Bump-steer is a change in toe* angle caused by the suspension moving up or down. Bump-steer is built into the geometry of the suspension and steering system, and has nothing to do with turning the steering wheel. The effect of bump-steer is for the wheel to toe-in or toe-out when the suspension moves up or down. This toe change or "steering" occurs any time the suspension moves, whether it is from body roll, brake-dive, or hitting a bump in the road. Bump steer is undesirable because the suspension is steering the car instead of the driver.
The front wheels do not move directly straight up or down when the car hits a bump. Instead, the wheel follows an arc, or curving path, that pushes the wheel slightly inward (towards the centerline of the car) or outward (away from the car) in response to vertical wheel movement. The outer tie-rod (which connects the steering rack to the wheel) also moves in-and-out in an arc as it moves up and down. If the rate which the outer tie-rod arcs in or out does not match the rate the wheel moves in or out, the wheel will be turned by the tie-rod. This is bumpsteer.
The center point of the arc traveled by the wheel (known as the instant-center) is controlled by the location and angle of the moving suspension links. This point moves as the ride height changes. In contrast, the arc of the outer tie-rod is controlled by the position of the steering rack, which is fixed. In order to eliminate bumpsteer, both the length and the center point of the two arcs must be the same. However, since the instant center moves with ride height, bumpsteer cannot be eliminated throughout the entire range of suspension travel. Therefore suspension designers concentrate on minimizing bumpsteer within the range of movement closest to factory ride height. Changing the ride height or other suspension components may move the suspension outside this narrow "optimized" window.
Resolved 2015 ecoboost pp bumpsteer issue
  • matthewt
  • Aug 1, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Aug 3, 2026
fasterthangas
F
Suspension Maximum Motorsports Tapered Bumpsteer Kit MMTR-2 - Replacement Spherical Rod Ends
  • AeroCoupe
  • Mar 30, 2025
Fox 5.0 Mustang Tech Mar 30, 2025
AeroCoupe
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
