what does a ccrm cost?
frcefedlx
184
I beleive my ccrm is dead and would like to know what others have paid for a replacement. I can unplug the ect sensor and the fan comes on. If I turn on any of the AC settings I get nothing from the fan. If I drive around the car will get warm enough that I dont want to drive it. I also do not have any voltage at the fanplug when car is running and temp is hot. From everything I read it sounds like this is the problem and am curious as to what this part will set me back.
If you feel like doing testing, see the third bolded section here. The diagrams might be helpful too.
A little more info
From what I've seen, new CCRM's go for 150-200 bucks from the dealer. Used they go for 10-25% of that. If you do the testing in the first link, you should know if the EDF or HEDF relay is bad for the fan. If not, the fan portion of the CCRM is probably ok.
Good luck.
