OneStiffGT said:
Thtat does not mean that, they wouldn't do better if they revved higher.
it's a v8, and an american v8 at that. Torque is what is good to have. For example if I have 500ftlbs of torque on hand at 2500rpm and a table top smooth band with only 20-40ftlbs of lose to say 5800rpm that gives me a useable powerband of 3300rpm right? Ok there is this thing called a transmission and a shifter USE it to keep in the powerband. Whereas the guy with a 8k engine where is his torque peak?? I'm going to guess closer to 5 or 6k and he is going to have to keep the rpm's up in order to stay in that band. Which takes alot more attention to the engine not to mention the increased cost of the powerplant.
Now things to consider if your serious about it. Your going to need a good bottom end. I'd suggest an explorer block ( the AL ones), a forged crank, forged rods, forged pistons, and al the necessary other things. Such as have the oil holes chamfered, and radius, block stress releived, good oil pump (cobra pump maybe? ). Then on to the topend, your going to need heads that flow like crazy, and I'd suggest a custom cams, cause I serously doubt anyone makes one with 8k rpm in mind for the 4.6 sohc. I'd also suggest a new intake, reichard racing or a custom job, maybe the one from MM&FF build up? . Find a tuning shop that will tune the cr to 8k rpm.
Then your going to want to lighten everything you can so you can get the car into the powerband. ie Ti valves, retainers, AL, flyweigh, CF dS, dump as much weigth off the car as possible too. ie replace panels, ditch anything that you can.
Or get a dohc car.
Or more power available sooner ie poweradder. Turbo would be my suggestion
