ATF NON-synthetic
Synthetic fluids are great and all, but sometimes they are not the best for an application. In a transmission, conventional fluid is more than adequate to cool the bearings and lubricate it. The problem with modern blocker ring transmissions is that they need some friction in order to shift. Using a fluid that's less slick sometimes lets the synchros grab better.
This is actually what tremec recommends as a band-aid on the 3650 which has 1-2 shift problems.
The t-5 was engineered for conventional ATF. If you want to run synthetic that's fine, but if your trans grinds occasionally, you may find that conventional fluid may fix the problem for you.
That's why i just tell people to run conventional ATF from the begnning...2.8 quarts.
