4-6 psi should be enough as long as it doesnt drop at WOT.
you dont want it above atmospheric pressure (about 7 psi)
ill have to look into that... i know you want less than 7 psi as a general rule, and atmospheric pressure is the reason why.
The average atmospheric pressure, at sea level, is about 101.3 kilopascals (about 14.7 pounds per square inch).
most pumps on the market are preset at 7 psi.the main reason I ask, is that Aeromotive makes an electric fuel pump that is fixed at 7lbs and no regulator is required.
Sounds like they didnt do their homework, the should offer it fixed at 6lbs
I ordered their other pump that is not fixed at 7lbs, and one of their regulators.
Good topic, don't mean to hi-jack but... I'm running a Holley mechanical pump #HLY-12-289-11 rated at 6.5 to 8 lbs. The fuel pressure guage which is connected to the fuel line at the carb is reading between 9-10 lbs. I don't notice any leaks, but when I step on it, I get a lot of smoke out the tailpipes and smells rich. Would the higher pressure cause it to run very rich on heavy acceleration?
In a carb setup, the fuel pressure cannot be greater than that needed to overcome the pressure exerted by the float in the fuel bowl this is needed to keep the needle/seat valve closed. The actual pressure needed depends on the carb. A bigger float would allow a higher line pressure to be run as it would exert more pressure on the needle valve. This is the reason you should always run a regulator with an electric fuel pump.
