Look at my sig...I have a 5 spd. I start in 2nd gear and still have problems heating the tire enough to launch.. I know I have those piece of sh!% Kumhos, but has anyone ever started in 3rd???????
actually a nice little burnout WILL help a street tire hook better. A 2nd gear burnout is a little overkill. I do a first gear bo for about 5-8secs and that seems to work perfect. If you are just turning your tires over for a split second, be prepared for some 2.2 60's unless your track is the *****HIGDON said:Overheating a street tire will actually DECREASE it's ability to grip. All you need to do is drive around the water and do a quick clean-off burn out to get the loose gravel and dirt off.
i heard i cut 1.9 60' on street tires doing burnoutsFallenPhoenix said:Someone told me that if you try to heat up a non-drag radial tire you'll actually bring slick oils to the top instead of making it stickier.
everyone i've talked to has said doing a small burnout on street tires helpsSilly34 said:I have first hand experience on this. DO NOT burn out on your street tires, it brings out all the nasty slick $ht, just spin them enough to knock the crap off of them.
B.
it seemed to help medid you cut 1.8s by not smoking them????Silly34 said:I have first hand experience on this. DO NOT burn out on your street tires, it brings out all the nasty slick $ht, just spin them enough to knock the crap off of them.
B.
I know a few guys with stock gatorbacks that have pulled 1.9s(justsomeguy is one). I have pulled 1.9s on sumitomos and michelin pilots. I havent done it on khumos yet, but tarzan has pulled high 1.8s to low 1.9s on his he said.FallenPhoenix said:what tires are on your car jackie? Got to be something better than the stock Gatorbacks...
