What Gears do I have?
  • Thread starter Thread starter CranberryCoupe
  • Start date Start date Oct 3, 2010
C
CranberryCoupe
Summerville, SC
Oct 3, 2010
  • Oct 3, 2010
I have searched and cannot find an exact answer to my question. I bought my mustang and the guy before me did no know if the gears had been changed. I have a 93 5.0 manual. I drive it to work on the freeway for an hour on the occasional nice day and it just seems like 80mph at 2500 rpm is a little high or it could be that it has no cats and is just that loud. Can you guys tell me what ive got back there?
thanks,
Brian
R
RatStang
544
  • Oct 3, 2010
Jack up the back of the car and put it on stands. Mark the inside sidewall of your tires, secire the other from rotating. Put a lateral line on teh driveshaft. Rotate the onseure wheel one complete revolution while counting the number of times the driveshaft rotates.
C
CranberryCoupe
Summerville, SC
Oct 3, 2010
  • Oct 3, 2010
Thanks...... I feel kind of stupid I couldnt figure that one out myself
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Oct 3, 2010
  • Oct 3, 2010
Isn't that going to make the driveshaft turn half the amount that it should? If you make sure both rear wheels make one full revolution, count the driveshaft turns, that is the ratio. If one wheel is fixed, the ring gear is turning at half the speed of the rotating wheel, via the spider gears.
XStanger
383
  • Oct 4, 2010
Sounds like 3.73's to me.
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Oct 6, 2010
  • Oct 6, 2010
You left off some important information... Like what size tires you're running. And you need to be very accurate in your other figures, or any estimation of your gear ratio will be off.
For example, if you're running 26" tires, and your RPMs are exactly 2500 @ exactly 80mph, then you have 3.55 gears. If the RPM is more like 2625 @ 80mph, then you'd have 3.73s.
If the gears were swapped and the speedometer wasn't corrected, then you can't use speed and RPM to figure out the gear ratio. The stock tachometers can be terribly inaccurate too.
BTW... Here are the formulas:
Tire Height (in.) = Tread Width x Aspect Ratio ÷ 1270 + Wheel Diameter
Rear End Ratio = Tire Height x 0.002976 x Eng. RPM ÷ Trans. Gear Ratio (0.68 for a '93 5-speed) ÷ MPH
Do the wheel rotation method, but turn the wheels 10 times and count the driveshaft rotations (get a helper for this). It's easier to tell the difference between 35 and 37 rotations (3.55 or 3.73 gears) verses 3.5 and 3.7 rotations. Trust me.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
9
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
