You left off some important information... Like what size tires you're running. And you need to be very accurate in your other figures, or any estimation of your gear ratio will be off.
For example, if you're running 26" tires, and your RPMs are exactly 2500 @ exactly 80mph, then you have 3.55 gears. If the RPM is more like 2625 @ 80mph, then you'd have 3.73s.
If the gears were swapped and the speedometer wasn't corrected, then you can't use speed and RPM to figure out the gear ratio. The stock tachometers can be terribly inaccurate too.
BTW... Here are the formulas:
Tire Height (in.) = Tread Width x Aspect Ratio ÷ 1270 + Wheel Diameter
Rear End Ratio = Tire Height x 0.002976 x Eng. RPM ÷ Trans. Gear Ratio (0.68 for a '93 5-speed) ÷ MPH
Do the wheel rotation method, but turn the wheels 10 times and count the driveshaft rotations (get a helper for this). It's easier to tell the difference between 35 and 37 rotations (3.55 or 3.73 gears) verses 3.5 and 3.7 rotations. Trust me.
