What Have I Done???
  • Thread starter Thread starter projectfiveo
  • Start date Start date Oct 13, 2006
First Prev 2 of 2
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
Oct 15, 2006
#21
  • Oct 15, 2006
  • #21
gonna have to get under the car and start inspecting things. check everything that moves underneath the car. u joints are my guess also...but it could be other things as well.
txstang84
1,639
42
69
Tuscola, tx
Oct 15, 2006
#22
  • Oct 15, 2006
  • #22
just a shot in the dark here...but if you're getting a loud thump when you get on it hard, ck your tranny mount. if you're still running the stock rubber mount, it may've gone south and the torq applied during takeoff is causing the tranny to thump the tunnel.
All of my friends with f-bodies had that problem at least once, they'd tear the stock rubbing mount in half and the tranny would smack the floorpan and make you think the car was coming apart...I can't really say I've known anyone with a Mustang have that problem, but most people replace those components shortly after buying the car.
u-joints are a very distinct possibility like a lot of these other guys are saying, but while you're under there, ck the tranny mount as well...just grab the tailshaft housing of the tranny and push up on it, if the mount separates, you've found your problem. A new poly tranny mount will run you about $30 from most places, both Energy Suspension and Prothane make them for our cars.
good luck!
P
projectfiveo
347
Nov 12, 2006
#23
  • Nov 12, 2006
  • #23
Ok so i finally got a chance to look under my car and the only thing i could find wrong was some play in my front u-joint, so could that be causing my problem? would that cause the thumping noise from around the shifter area?? and also since i have a alum driveshaft will i need to buy special u-joints? and how much they run?
Jaswir
578
Orlando, FL
Nov 12, 2006
#24
  • Nov 12, 2006
  • #24
i think he broke something else... yes you should wait to get on it and break them in (couple heat cycles) but ive known people to get on it right after they get it installed and never had any problems but u never know... get underthere and check everything out
First Prev 2 of 2
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
