What Heads Cam And Intake????
ninefiveGT
37
Michigan
I have a 95 gt with 106,000 miles and i am looking to put heads cam and intake on it. I was wondering what would be the best combo for under 2 grand. I have 3:73 gears, underdrive pulleys, and BBK LT headers. Thanks
you will find your heads cam and intake for under 2 grand but not much else to complete the install. Lifter, Rockers, bolts, gaskets, are all going to put you over your limit. The following prices are out of the latest mustangs unlimited catalog that I just recieved today.
Trick Flow heads--1095.00
Trick Flow Street Heat--399.95
Trick Flow Cam--139.95
Lifters--119.95
1.6 Rocker Arms--239.95
Rocker Stud Set--42.95
Rocker Shim Kit--8.95
Push Rods--39.95
Head Bolts--39.95
Head Gasked Set 1986-1993--99.95
Total Install Package 2226.55 not including shipping or installation.
If you can find the deals I did :D Just gotta be patient and have the money to make a move QUICK when they pop up.
NMRA Low pass # GT40P factory stock heads, MAC NMRA prepped shorty headers, 1.6 Scorpion rockers - all for $1,000
97 Explorer intake with 65mm TB and Bosch Design III 19# injectors - $200.
Haven't decided if I'm going to put a cam in or use the stocker. I may pay for cam modeling and see the difference in the recommended cam and the stocker.
tmoss said:
AFR 165s - $1,350
Crower 15511 - $300
Ported used Cobra/Explorer - $380
[by me :o)]
$2,030
I'm with Tom on this one!
There is a dyno pull with these parts, I think, on this board or on the Corral and the numbers look good.
Nice wide & flat tq curve.
Later
Grady
Later
Grady
Here it is............
http://forums.stangnet.com/showthread.php?t=388475
Very nice torque curve - don't get hung up on peak numbers - average numbers across the rpm band!!!!!!!!!!!
