What intake manifold??
  • Thread starter Thread starter sandman0023
  • Start date Start date Nov 4, 2004
First Prev 2 of 2
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 5, 2004
#21
  • Nov 5, 2004
  • #21
It's big enough, the openings will match.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 5, 2004
#22
  • Nov 5, 2004
  • #22
stang2841 said:
for a GT40 engine with a cobra intake
and a custom cam would a 65mm be ok?
what is the opening on a cobra intake?
Does the "gt40" engine not come with a Gt40 intake? It flows just slightly better than the cobra I believe...
Alls a gt40 engine is...is a new bottom end (like from the factory) with an alphabet cam/gt40 heads, and intake...
The 65mm will be fine on that engine...
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Nov 6, 2004
#23
  • Nov 6, 2004
  • #23
GT40 heads -- would that be the GT40 irons (Cobra, early Explorers), the iron GT40P's (late Explorers), the aluminum GT40Y's (turbo-swirls), the aluminum GT40X's (turbo-swirl Xtra Performance) or the GT40Z's?
The Cobra, GT40 and Explorer intakes all share the same "GT40" lower intake as far as the runners/flow goes (some drilled and tapped for different sensors, etc.).
As you can see, there's no such thing as a "GT40" engine.
stang2841
708
palm harbor florida
Nov 6, 2004
#24
  • Nov 6, 2004
  • #24
My bad, I want to put basically a cobra engine in my car but with a custom grind
so I'm gona be hunting for some GT40's not "P"
and find a normal cobra intake and do some light work to the lower and port up the GT40's find a custom cam or a anderson cam and get a 65mm acuffab throttlebody.
I was wondering the opening size on the cobra intake though? and what size mass air would you reccomend?
I was looking at the densecharger set ups because they looked realy clean
I'm sry for the GT40 statement beleve me I know the varietys, I've been lookin around for some OEM ford parts for the daily driver and to pull 300rwhp with them
I was lookin at the GT40's and some windsor heads but I do not know where to look with the windsor heads, Is it possible that windsor some windsor heads flow better then the GT40's?
I'm kinda turned off with the GT40P's for the fact that it was on an explorer and that its hard to find some longtubes with them
is the GT40's a 64cc combustion chamber like the E7's ?
PhLoBuS
473
Beverly, MA
Nov 6, 2004
#25
  • Nov 6, 2004
  • #25
I say if you plan on going with a TF Street Heat go with a 70mm since the opening is that
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 6, 2004
#26
  • Nov 6, 2004
  • #26
75mm is the opening, but good advice none-the-less.
PhLoBuS
473
Beverly, MA
Nov 6, 2004
#27
  • Nov 6, 2004
  • #27
Should I go with the Street Heat which is idle-5500 rpm or the performer rpm 5.0 which is 1500-6500? I dont really pull the rpms to 6250 anyways
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 6, 2004
#28
  • Nov 6, 2004
  • #28
On your near stock car? The street heat is fine. I use it on my h/c/i car and its fine too. A track heat or am RPM will probably help me, but they really arent a cost effective mod right now. I run the 75mm TB and it works great! The Vortech im ordering will help me get more air in
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Nov 6, 2004
#29
  • Nov 6, 2004
  • #29
Yes their is an engine based on that if you go by it's commonly labeled name...Gt40 engine...I hear people refer to it as this all the time...and I was simply explaining that all's the "gt40" engine is...is gt40 heads, same style shortblock with B303 or E303 cam and intake...I was saying that it wasn't anything special...
It is just over 3k...it has the SVO gt40's on it...
stang2841
708
palm harbor florida
Nov 6, 2004
#30
  • Nov 6, 2004
  • #30
I only said GT40 engine to save me the trouble of going through the set up
seijirou
2,417
DFW
Nov 6, 2004
#31
  • Nov 6, 2004
  • #31
Get yourself a pair of 42mm throttle bodies!
First Prev 2 of 2
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
F
California, Daly City representing here! Hello!
  • FATTS_DC
  • Feb 9, 2025
  • The Welcome Wagon
The Welcome Wagon Feb 10, 2025
LILCBRA
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
