Grunter said:Tmoss - I don't see generalization in a 266,AFR's 165 and an RPM11. This is pretty darn specific if you ask me! I did not test his combo - I said I've seen it tested many times! Muscle Mustangs and Fast Fords has had many different variations and Westech Dyno as well. Richard Holderner's book dyno sessions shows it clearly!
Well tuned - this package is very stout(400+hp) I've seen a bit less - but usually cleaned up with fuel pressure, timing adjustments!
Grunter said:By the way - I like your set up as well, I was thinking if not AFR's then GT40P's well prepped as you seem to have them. I hear getting good headers is difficult. And 4 degrees advanced seems to help things with the stock cam.
Depending on cam choices - I have seen GT40P's in the elevens! It's a worth while set-up by far!
Anyway, please let me know Tmoss how you do/fare with your combo - it's one I've had my eye on for a bit! That one and the 266......
. I like the combo VERY much. I have instant access to mega-torque across the rpm band for what it is. It's almost too much for the 9.8" contact patch tires I run in normal driving. My stock SD cam has valve events VERY close to the baby Crower 15510 cam - just has less lift @ .47X" lift. I'm about done with it as I drive this car a LOT and i want to retain driveability. I also want to stick with Ford parts just cause I'm old school at heart - mod what the factory gives you. F/S blood runs in my viens I guess.Amen brothertmoss said:You know what we REALLY need? A magazine that does not have to tip-toe around the issue of stepping on advertisers toes to create worthwhile tech articles and tests.
Grunter said:The clear winner is the RPM11. Mind the performer rpm is within 1-2hp and about the same in torque all the way to 5500rpm where it surrenders to the RPM11.
304billet said:Have the GT-40 extrude honed in prep for the blower.
