  • 2005 - 2009 Specific Tech
what is a charger motion plate?
  • Thread starter Thread starter chubhunter
  • Start date Start date Apr 12, 2007
C
chubhunter
63
heartland
Apr 12, 2007
  • Apr 12, 2007
Just curious about what a charger motion delete is all about. I've seen it in several other threads. What does it do and why would you get rid of it.
ScottM
219
Little Rock, AR
Apr 12, 2007
  • Apr 12, 2007
Charge motion plates are plates located in the intake runners that have butterflies controlled by a motor that open and close depending on the position of the throttle. The delete plates get rid of the butterflies, thus ridding the intake of any obstructions. Some people have reported the butterflies malfunctioning and staying closed causing big problems, so some see it as a safety precaution. You do need to tune for them though. I have them and am happy with them. I swear I could feel a difference, but it might be a placebo effect. They are an inexpensive mod ($120 or so) and even if they are only worth around 7-8 horses, every little bit helps.
I'm sure I've got some of the terminology wrong, but that's pretty much the jest of it.
ScottM
219
Little Rock, AR
Apr 12, 2007
  • Apr 12, 2007
I found a better explanation then would I could give...
"At the end of each intake runner was a new-to-Mustang feature Ford called a charge motion control valve. At low engine speeds and light loads, these specially shaped control flaps closed to speed the intake charge and induce a tumble effect in the combustion chamber. That caused the fuel to mix more thoroughly and burn more quickly and efficiently. At higher engine speeds, the charge motion control valves opened fully for maximum flow into the combustion chambers."
jerzeykilla
72
  • Apr 12, 2007
called the guys at brenspeed...says you would be lucky if you got 4-5 hp out of them.
ScottM
219
Little Rock, AR
Apr 12, 2007
  • Apr 12, 2007
All dyno's are a little different, maybe they only got 4 or 5 horses, but maybe someone else picked up 7 or 8, maybe even 9 because the conditions were just right or better than when Brenspeed did thiers. Personally, I couldn't care less whether it's 4-5 or 7-8, I'm more concerned with getting down the track faster which these help do. Plus, I learned how to take my intake off installing the plates which I've never done before.
Odd that Brenspeed would say it that way though, they sell them, you'd think they'd try to sell them versus trying to turn people away.
Black07GT
42
Rochester
Apr 13, 2007
  • Apr 13, 2007
Do you notice a quick throttle response time with the install? I would imagine that removing the "valve" would eliminate any WOT valve actuation delay and let the engine breathe quicker. Let me know, because if it does have this effect, then maybe it is worth it to me, otherwise it is not worth my time...
P
Pro Mod
236
Wharton, WV
Apr 13, 2007
  • Apr 13, 2007
I picked up 1.2 mph in the 1/8-mile with my cmrc deletes with the accompanying BamaChips tune (I already had a tune, I just got the updated Bama tune for the cmrc's). Maybe Doug just makes a better tune for the cmrc deletes?
ScottM
219
Little Rock, AR
Apr 13, 2007
  • Apr 13, 2007
Again, I'm not sure about HP gains, but overall drivability improved. Throttle response has increased as well. I think it's a great mod and would do it again. There are no downsides to it and every little bit helps. By the way, I have a Bama tune as well.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Apr 13, 2007
  • Apr 13, 2007
brenspeed does not push items that customers dont need. they are pretty honest and will tell you when you dont need a certain mod, or if money can be better spent elsewhere.
C
chubhunter
63
heartland
Apr 13, 2007
#10
  • Apr 13, 2007
  • #10
Thanks to all for the information. Sounds like something I could probably do myself. I've got a few other things do to first, I'll just add that one to the list.
s
ScottM
219
Little Rock, AR
Apr 13, 2007
#11
  • Apr 13, 2007
  • #11
Understandable, I think. The plates don't give you near the satisfaction or effectiveness as say gears or LT's, but they also don't cost near as much either. If I needed every little bit of money for certian mods and couldn't spare any, I would definately skip them, but for about a 100 bucks and being able to install yourself, I think it's just one of those things that you might as well do.
Just out of curiousity, have you heard of anyone not happy with them (serious question, not trying to be a smart ass)? I don't recall reading anyone having any trouble with them or recieved negative performance from them.
There are other things that I would do first before the plates, but for the money, they aren't a bad mod.
bigcat
May 1, 2005
3,015
7200 feet
Apr 13, 2007
#12
  • Apr 13, 2007
  • #12
i heard of one instance, but i believe it turned out to be a tune related issue.
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
W
Jay, Old Bodyman , but new here :-)
  • WonderWoody
  • Nov 18, 2026
  • The Welcome Wagon
The Welcome Wagon Monday at 6:50 PM
AeroCoupe
Can ya Hemi now?
  • RaggedGT
  • Jul 2, 2026
  • Other Auto Tech
Other Auto Tech Jul 2, 2026
RaggedGT
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Nov 12, 2026
ctandc
C
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
