What is a normal operating temp?
  • Thread starter Thread starter redpwny
  • Start date Start date Mar 12, 2012
redpwny
26
East Valley, Arizona
Mar 12, 2012
  • Mar 12, 2012
Besides the gauge being in "normal" range, It seems a bit high. I finished my tune up yesterday, with all new oil, filter, air filter, sparkplugs, wires, cap and rotor. It never ran warm before the tune up. Now it likes to sit a little above half way. It does not climb higher than that, though... it's about where the hour hand on clock would sit if it were about 930 to 10. Coolant is topped up, the water pump looks new, and fan clutch is good. Does not overheat, just sits high. Thermostat, correct? Do they make thermostats that keep it running a little over the middle of the gauge? Seems odd, is all. I bought a 180deg thermostat I will be installing for peace of mind, but I hope to gain a little insight as to why the car would do this all of a sudden after a tune up.
Thank you!
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Mar 12, 2012
  • Mar 12, 2012
There's no logical reason why doing a tune-up would make a car run noticeably hotter. That said, a 180* t-stat will certainly lower the operating temperature of the engine. What is the condition of the rest of the cooling system? Radiator? Coolant? Waterpump? Fan clutch?
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 12, 2012
  • Mar 12, 2012
As part of your tune-up, did you advance your timing at all?
redpwny
26
Mar 13, 2012
  • Mar 13, 2012
Yeah I know, I've been working on cars enough to know that as well, there's no reason for it to run warmer. I did not touch the timing, but you never know, maybe I advanced it by accident when dealing with the cap and rotor? I doubt it, though.
The rest of the cooling system is fine- it's a low mileage car, about 120k miles, new water pump, coolant is nice and clean, rad, not sure. Cap is fine. Fan clutch, seems good... so yeah, I'm thinking thermostat. I'll do the 180deg and see what's what.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Mar 13, 2012
  • Mar 13, 2012
Don't be too concerned with the gauge. The stock temp gauge is little more than a glorified dummy light. Personally, I'd leave the stock T-stat right where it is unless you run into any legitimate cooling problems. Stock coolant temps generally run anywhere from 190F-210F in normal operating range. Lowering the operating temperature will affect your fuel economy, contribute to engine wear, increase emissions output, shorten your oil change duration and have a negative impact on your ECU function. You might get away with a 180F T-stat, but like the old saying goes....if it ain’t broke, don't fix it.
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Mar 13, 2012
  • Mar 13, 2012
I believe I read in a 5.0 Mustang Performance Handbook somewhere that about 200 degrees was an optimum operating temp for the fuel injected 5.0.
redpwny
26
Mar 13, 2012
  • Mar 13, 2012
Alright, thank you both for the answers. You are right about the adverse effects of going with a lower temperature thermostat- and the car does not ever overheat, so... I will just leave it where it is and keep an eye out for any overheating in the future.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Mar 13, 2012
  • Mar 13, 2012
Hence the stock thermostat being 195 degrees. Wow, those Ford engineers were really onto to something. huh?
Dino Dino Bambino
1,672
89
79
Cyprus
Mar 13, 2012
  • Mar 13, 2012
Sounds logical. The stock t'stat opening temp. is 192*F and the low speed electric fan on the SN95 5.0 comes on at 208*F, so it seems Ford intended the 5.0 to run in the 192-208*F range.
A 180* t'stat won't cause any problem. I've been running one for more than 4 years.
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Mar 13, 2012
#10
  • Mar 13, 2012
  • #10
"Don't be too concerned with the gauge. The stock temp gauge is little more than a glorified dummy light. Personally, I'd leave the stock T-stat right where it is unless you run into any legitimate cooling problems. Stock coolant temps generally run anywhere from 190F-210F in normal operating range. Lowering the operating temperature will affect your fuel economy, contribute to engine wear, increase emissions output, shorten your oil change duration and have a negative impact on your ECU function. You might get away with a 180F T-stat, but like the old saying goes....if it ain’t broke, don't fix it."
My gauge went up two letters when I went from a 180 to a 195 deg F thermostat, but it no longer smells so rich as to sting your eyes when your park it in the garge or stop at a stop sign. Get a real gauge to test if you are worried.
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
Mar 14, 2012
#11
  • Mar 14, 2012
  • #11
Tstat sets the lower temp limit not the upper temp limit. A 180 means it won't get any colder than 180 once engine reaches operating temp & tstat opens. Radiator, coolant flow & air flow through it set the upper temp limit.
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Engine RPM cut out intermittently
  • RotFox90
  • May 5, 2024
Fox 5.0 Mustang Tech Jun 11, 2024
RotFox90
G
2001 Mustang Gt
  • gilmo5
  • Sep 10, 2024
1996 - 2004 SN95 Mustang -General/Talk- Sep 10, 2024
gilmo5
G
