what is going on here???
  • Thread starter Thread starter 87foxstang
  • Start date Start date Sep 20, 2007
87foxstang
Cromwell, CT
Sep 20, 2007
  • Sep 20, 2007
ok, as you can see in my sig i have 4.10 gears, well that was like the only mod to the car when i bought it 3 years ago, at least thats what the guy said. Sometimes i doubt they are 4.10's. So i tried the test the other day, jack the car up put it in first gear, rotate the tire and watch how many rotations the driveshaft makes for every one turn of the tire. Well everytime i try this i only get 1 3/4 rotation of the drivesaft for one turn of the tire!!!WTF I may have posted this in the past but i always think im doing it wrong so i try it again, and always the same thing!!! help would be appreciated lol thanks guys i just want to know what gears i REALLY have
sorry for the long post
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 20, 2007
  • Sep 20, 2007
Your test isn't working out right
What rpm are you cruising at at 70mph?
87foxstang
Cromwell, CT
Sep 20, 2007
  • Sep 20, 2007
not sure about 70mph, i dont go that fast
but at 65 its at about 2800 or so
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Sep 20, 2007
  • Sep 20, 2007
You are supposed to put the car in neutral. get under there with a marker or something and just watch very carefully.
grey5.0beast
Aug 3, 2004
atl ga
Sep 20, 2007
  • Sep 20, 2007
Sounds like 4.10s to me. I cruise at 60 in 5th and its at 2k rpm with 3.73s
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 20, 2007
  • Sep 20, 2007
2,800 at 65mph?
Sounds like either a short tire and 4.10's...or your looking at 4.30/4.56 gears.
87foxstang
Cromwell, CT
Sep 20, 2007
  • Sep 20, 2007
ohh neutral huh, i thought i tried it both ways and it still didnt add up lol i guess ill have to give it yet another shot this weekend so 3.73's at 60 is 2k huh, so maybe i do have 4.10's
87foxstang
Cromwell, CT
Sep 20, 2007
  • Sep 20, 2007
as far as a small tire, i think its bigger than stock, i have a 245/50/16
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 20, 2007
  • Sep 20, 2007
Those are shorter tires, but barely.
The 245/50/16's (which is what I have) is 25.64" tall.
The stock 225/55/16's are 25.74" tall.
That difference will not be seen on a stock mechanical tach.
Shorter tire height equals more rpm at cruise.
Taller tire height equals less rpm at cruise.
Many drag racers or track guys will get a taller tire, if they are running out of rpm at the end of the 1/4 mile.
408gt91
114
N.H.
Sep 20, 2007
#10
  • Sep 20, 2007
  • #10
blckstng96
208
#11
  • Sep 21, 2007
  • #11
keep in mind the speedo is prob reading incorrectly because there isnt a ford speedo gear for 410s,u would have to pull the trans apart to correct it or get the one that is for dodge i think and it doesnt mesh perfectly,thats the one i got.
87foxstang
Cromwell, CT
Sep 21, 2007
#12
  • Sep 21, 2007
  • #12
yea...i guess ill just find out this winter for sure, i have a small amount of drippage coming from the rear end and i plan on re sealing it, and then ill just take a peek at the gears lol.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 21, 2007
#13
  • Sep 21, 2007
  • #13
Just do the test in neutral.
Jack up one tire if you have an open diff, or both tires if you have a working posi or locking differential. Rotate the tire one full revolution for posis and lockers and 2 full revolutions for open diffs. Carefully count the number of full revolutions the driveshaft makes. This is your gear ratio. In other words, if the drive shaft turns 3 ¾ turns, you probably have a 3.73 gear ratio. Turning the tire for twice the number of full revolutions and dividing the drive shaft revolutions by two will give you a more accurate reading.
87foxstang
Cromwell, CT
Sep 21, 2007
#14
  • Sep 21, 2007
  • #14
whats an open diff, im retarted when it comes to identifying rearends, i have the stock rearend, so would i do 2 rotations?
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
