I'm not sure if I have ever seen a 351W in a 65-66 where one header or the other did not contact a shock tower. The fit is tight. You should factor in motor mounts that allow some adjustability so you can center the motor for best header clearance on each side. The Ron Morris and TCP mounts do this, I believe. The other potential issue is hood clearance. Some care has to be taken when choosing an intake manifold and drop-base air filter.
