I have the FR in my car.The first problem i had was that the plastic bushing on the bottom of the column didn't like heat. The plastic would expand and the steering would bind. Second problem was the harness getting pinched inside the column and shorting out . It was caused by the grommet being slightly to thick and not allowing enough clearance between the shaft and housing.
Customer service was very good in resolving the bushing problem,But im not the only one that's had a short in the wiring harness because of it rubbing.
