  • SN95 4.6L Mustang Tech
what is the diff between rai and cai?
  • Thread starter Thread starter mustangkid05
  • Start date Start date May 17, 2006
1 of 2 Next Last
mustangkid05
199
  • May 17, 2006
so what is the diff between the two??
romaine
BurningRubber
1,865
24
58
May 17, 2006
  • May 17, 2006
Cold air induction is just that... a high flowing filter mounted where it will suck in the coolest air it can. Most if not all CAI's are fenderwell mounted so the filter is kind of protected from water and alot of dirt, cooler air in there also.
Ram air induction is better. Its basically mounted up so there is something that scoops, or gets air rammed directly into it as speed increases. At a stop, its basically a CAI. The faster you are going, the more are you are sucking up. The air being forced into the intake then gets sent to the filter, and it functions like normal from there. March's ram air has a scoop that mounts in the bumper I think, and it scoops air from down there up to the air filter, but that can act like a big vaccum cleaner kinda...
DropTopPony
Noob Slayer
2,570
south jersey
May 17, 2006
  • May 17, 2006
Prove it!
02FastblackGT
64
Tucson, AZ
May 17, 2006
  • May 17, 2006
CAI have filters placed outside of the engine bay. Since the filter is out of the heat created by the engine, it is therefore cooler. It has been proven that cooler air creates more HP. The downsides to having your filter outside of your engine bay are the threat of rain/deep flooding causing water to be taken in by the filter, therefore hydrolocking your engine. Also, if the filter has a direct air flow from outside air, it might be possible to get dirtier quicker, as opposed to a filter underneath the hood. One thing I know from living here in the desert...the air outside isn't much cooler than the air underneath my hood. I would much rather have the peace of mind while driving in the rain/through flooded areas, that I don't have to risk hydrolocking. Just a few things to keep in mind before buying...
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
May 17, 2006
  • May 17, 2006
aint it that Ram air really starts to do its job when you are going around or over 100mph
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
May 17, 2006
  • May 17, 2006
Thats what I thought
PlatinumDevil
Regina, Saskatchewan, Canada
May 17, 2006
  • May 17, 2006
Yes but its still very cold air, probably alot cooler than the air coming from the CAI intake. Depending on where this ram air is located. If its the mach1 style than it will be much colder than a fender mount, if its the march kit it will be a similiar temperature(if not warmer) to the fendermount CAI...
My reasoning.... ever lie on the asphault on a really hot day, the march kit puts the 'snorkel' like 4 inches above the ground... not to mention you could make the march kit for like 8 dollars with flex pipe.
Its also important to note that the length of the intake piping affects your powerband by about 100-300 rpm. (why some people opt for short warm air intakes, or short-ram... personally i think its retarded, but hey, i dont drive a civic.)
mustangkid05
199
  • May 17, 2006
so youre saying basically a cai is more effective?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 17, 2006
  • May 17, 2006
CAI > stock intake > RAI
mustangkid05
199
#10
  • May 17, 2006
  • #10
so youre saying they are just as good as stock?!?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 17, 2006
#11
  • May 17, 2006
  • #11
Cold Air greater than stock greater than "ram air"
Because "ram air" is just a cheesy gimmick that you will wish you never installed.
BurningRubber
1,865
24
58
May 17, 2006
#12
  • May 17, 2006
  • #12
I dont see how a CAI will outperform a well set up RAI setup. Think about it... the ram air IS a cold air induction, but with the added benefit of more air being forced in the faster you are going.
Look at it like this, why do some people pull their headlight on the intake side when they go drag racing..? Thats extra air being shot directly at the intake... same concept with the ram air. If it didnt perform any better than a cold air setup, I dont see how it would be worse though... unless you talking price/bang for the buck wise.
Just my opinion on it though.
Y
Yellow2002GT
148
Raeford, NC/ FT Bragg
May 17, 2006
#13
  • May 17, 2006
  • #13
The biggest difference with the cold air kits over stock is that they are smoothed out inside which allows for less restricted air flow......relocating the intake away from the heat of the engine bay is always better but only really makes a difference if your at a stop for a while........a bigger volume intake like the AFM Power Pipe is the true way to go but without the supporting mods i.e. bigger TB, Plenum, MAF, and full exhaust it wouldn't help that much.....Now when I had all the supporting mods with the BBK Cold air intake I changed over to the power pipe and with a good dyno tune pulled out another 13 rwhp and 15 rwtq but it also required a Pro-M air meter.
"ED"
264 rwhp and 304 rwtq
AODE stock cams, heads and block daily driver
12.9@102 1/4
8.22@82 1/8
1.72 60ft
loosescrew79
313
#14
  • May 18, 2006
  • #14
For a cia to work to its full capability it needs the rest of the intake mods. Ram air may force more air in (yes at higher speeds) and so will larger and smooth intake tubes. But if you have the stock t/b and plenum you are just restricting the air flow again. Same as exhaust. You can't push more air into the motor than you have exiting
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
May 18, 2006
#15
  • May 18, 2006
  • #15
Also the "ram air" kits are typically a cheap plastic collector and some dryer vent tubing. They are typically overpriced for what you get.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
May 18, 2006
#16
  • May 18, 2006
  • #16
i dunno but i like the way the functional shaker hood looks on the Mach1 and the ram air look on the WS-6 but those cars came with it stock, so just get a CAI fendermount
hognutz
1,940
albany, oregon
May 18, 2006
#17
  • May 18, 2006
  • #17
ram air is so over rated for the money IMO.
I had a snorkle on my 72 nova bracket car. It ran 10.2-10.5 in the range at about 125-126.
I built a ram air box to force the air from the snorkle to the engine. it ran 10.2-10.5 at 126-127. I gained about 1mph wich is meaninless in braket racing for a decent as amount of work.
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
May 18, 2006
#18
  • May 18, 2006
  • #18
there is no ram air for a street legal car, however the Shaker and some of the falsely advertised Ram Air kits, are more efficient than just a normal CAI (my reasoning, air is being pulled in directly from the coolest possible place) However this may even be bs as most of the shaker and ram air kits have a lot of tubing before they get to the filter, and most of that tubing is in the engine bay....
But I still love my shaker.
If you're trying to save money just get a K&N filter only, and be done with it. If you want more power... well the debate has swung very much against the possibility of Ram Air, and is pretty much dead even on CAI vs Stock.
RaceDvr50
121
Coon Rapids
May 18, 2006
#19
  • May 18, 2006
  • #19
Yes cheesy ram air systems are likely worthless but a good rai is like a cai on steroids you get some amount of forced induction and in case some people have forgotten from the comments I've seen posted here forced induction like turbos and blowers is a good thing. Not saying you will get 10 psi out of a good rai because you won't but instead of sucking air, your intake will be under positive pressure and yes the faster you go the better it works.
hognutz
1,940
albany, oregon
May 18, 2006
#20
  • May 18, 2006
  • #20
I like the looks of the shaker. as long as someone relizes it is a styling mod and not much on the performance end.
I am calling unless you can show me some examples of real word gains.
I have done this. 1mph increase and no et gain on a 500hp car tell me there is not much steriods to a ram air. this was box than mounted to the carb, sealed to the hood right under the snorkle. that is about as ram air as it gets.
1 of 2 Next Last
R
Electrical Unknown wiring harness
  • Rockobrews
  • Jun 14, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 16, 2026
Rockobrews
R
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
J
Car won’t start
  • JLB
  • Nov 15, 2025
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
