Depends alot on how hot your coil is. I had an olds with DIS, you know the 3 coil packs? It ate a good set of wires once a year. When you see a light show under the hood at night, its time. You can measure resistance per foot and check specs to see if they are within tolerance, but I have not done that. I have found big differences, checking the difference in resistance from one brand to another. I chose wires of the same length and found the wires I took off my car to be quite a bit better than the ones I'm running.
Maybe. Look for the light show at night. Mist them with a little water from a spray bottle to simulate high humidity. Check resistance per ft on them and the ones you are thinking about buying.
They are Bosch, best quality they had at Discount. They work fine, had them for years now, but the old ones I have are better. They are Packard 8mm, never heard of them and they were on it when I got it 3 yrs ago. I replaced them along with alot of things trying to repair a part throttle pop in the intake. Turned out to be crappy GP Sorenson injectors.
