What is the little ground wire from Battery for?
91StangGT5.0
162
I've noticed there are two wires coming from the ground of the battery. One thick wire that goes to the timing chain cover and a thin wire that goes to the driver's side fender wall. What is this skinny ground wire for? I think it's been giving me problems. As of about two minutes ago, when I try to turn the car completely on it just clicks and shuts all electricity off and illuminates the check engine light until I open and close the door, then my alarm goes off and electricity comes completely back on. Then shortly after that all happens my car either does it again or starts right up. When I had the hood up I noticed when I turn the key to turn the engine on I noticed a spark from where the little ground wire meets the fender. I'm at a loss because I've cleaned connections, changed battery terminals, wires, etc.
  • Sponsors(?)
91StangGT5.0
162
So could this wire be the cause of my car's electricity shutting off completely and resetting it's self when I turn the key to start the engine? I notice my radio goes back to default setting and clock resets too.
cjrpony
439
West Michigan
If it is sparking then it is probably loose. Make sure your have a clean, tight connection where the wire meets the fender. I don't know if it is the source of all your problems, but its a start
Maryland Stang
1,656
27
39
62
Greenville, NC
I agree. That wire is supposed to be attached to the inner fender behind the battery. You must make sure it is attached there very well. There should also be a cable going from the back of the driver's side cylinder head to the firewall. All of these grounds must be well attached and clean. I think your problems will clear up once you take care of the grounds.
91StangGT5.0
162
I'm not seeing the ground from the back of the driver's side cylinder head to the firewall.....but rather a ground from the AOD bellhousing bolt to the back of the block to the firewall....
Also.. it seems that the ground to my electric fan shares the same ground location as the EEC ground wire behind the battery. My electric fan turns on with the key on and runs constantly (the way I wired it to do so). Could this pose a problem? Should I ground the electric fan ground somewhere else?
Thread starter Similar threads Forum Replies Date
Fairlane what are the two little ground wires off of the battery neg. for? Fox 5.0 Mustang Tech 1
NMEMJCM How much ground clearence is to little? Classic Mustang Specific Tech 5
M Electrical Little ecu wiring help, almost there! Fox 5.0 Mustang Tech 0
F looking for a little insight on a 302 swap for a 99 stang 1996 - 2004 SN95 Mustang -General/Talk- 6
L Finally finishing up the little 83. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
I Electrical Hi all! New here! Hoping to get a little help with a problem i am having on my 93 Foxbody! Fox 5.0 Mustang Tech 16
darryl paarman Going to need a little bit of help... Digital Self-tuning Forum 6
R Little Blue Coupe 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
H 66 mustang cold start blows a little carbon. 1965 - 1973 Classic Mustangs -General/Talk- 4
C Need a little advice on 2000 3.8 to 5.0 swap. 1996 - 2004 SN95 Mustang -General/Talk- 7
Steel1 Started a little modification here's some pics 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
L First Road Trip in the little Fox 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
owtblockchain A little custom mod I had done to my 2005 GT 2005 - 2014 S-197 Mustang -General/Talk- 0
C New guy...reviving this little guy.built it about 10 yrs ago,had to put it away after just a couple Hundred miles,sitting ever since Fox 5.0 Mustang Tech 26
C Electrical New fox body owner little worried Fox 5.0 Mustang Tech 29
Woody3882 I need a little help starting the 65 1965 - 1973 Classic Mustangs -General/Talk- 4
8 Little project I did 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
J 1993 Cobra ECM replacement Little Help please... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
A Need a little help with this project 1996 - 2004 SN95 Mustang -General/Talk- 0
Anti_Hero0932 Bigs and Littles tire size 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
A Looking for a Mustang but could use a little help. The Welcome Wagon 9
horse sence Shelby's little Red has been found 1965 - 1973 Classic Mustangs -General/Talk- 2
H Late 1967 - Little Box on back of Ignition Case Switch, What is it? (Have Pictures) Classic Mustang Specific Tech 3
D Did a little dressing up on the 5.0 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
2 Want more horsies for my little 6! 2005 - 2014 S-197 Mustang -General/Talk- 1
T A little Help Lowering Compression 393c w/ Brodix Heads 1965 - 1973 Classic Mustangs -General/Talk- 2
P New and a little lost on the 3.8 fox The Welcome Wagon 3
B Help! Wanna get a little info on trick flow heads and what i should expect from them. 1996 - 2004 SN95 Mustang -General/Talk- 0
Z 4 Gauge To 6 Gauge Cluster Swap - A Little Help 2005 - 2014 S-197 Mustang -General/Talk- 0
Global_Saffer Digital Tuning Need A Little Advice On My 'new' 07 Gt 2005 - 2009 Specific Tech 0
Jimmy K jam Hello All! I Need Little Help Please SN95 4.6L Mustang Tech 7
J Brakes Braking Issue Need A Little Help 1974 - 1978 Mustang II Talk & Tech 1
J New 96 Mustang, Have A Little $$$! 1996 - 2004 SN95 Mustang -General/Talk- 3
MzInvisible96 Newbie Here 96 Mustang Little V6 The Welcome Wagon 1
C Need A Little Help Fox 5.0 Mustang Tech 9
J Looking For A Little Knowledge For My 351w Fox 5.0 Mustang Tech 14
C Misfire That Fixes Itself For A Little Sometimes SN95 V6 Mustang Tech 2
P Little Help With This Color.... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
RaggedGT Progress Thread The Ragged Gt Thread-little To No Progress Made-Garage Art 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 164
B Need A Little Help With My 331 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
IIGood Paint and Body About To Get The Gt Freshened Up A Little (now With Some Pics) 1996 - 2004 SN95 Mustang -General/Talk- 32
D Shaker 1000 Hu Shuts Off, Need A Little Help 2005 - 2014 S-197 Mustang -General/Talk- 4
S Little Help - Transmission Swap / No Start 1996 - 2004 SN95 Mustang -General/Talk- 3
RaggedGT All Stangneter's-merry Christmas/happy Holiday 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
I candy Just Bought Car. No Book Need A Little Help Please 2005 - 2014 S-197 Mustang -General/Talk- 1
poboys 94 Need A Little Help With T-5 Clutch/ Cable 1994 - 1995 Specific Tech 15
R Need A Little Help 1994 - 1995 Specific Tech 1
A A Little A/c Issue.. The Welcome Wagon 0
LILCBRA A Little Help Needed With Codes.... Fox 5.0 Mustang Tech 5
lilzilla08 2004 Gt Throwing Codes, Need A Little Help! SN95 4.6L Mustang Tech 0
