what is this loud knocking?
  • Thread starter Thread starter twin_turbo_mk3
  • Start date Start date Oct 2, 2009
T
twin_turbo_mk3
31
  • Oct 2, 2009
okay so a friend of mine gave me a stock 1991 302 with roller rockers(crane cam) the motor ran great and we pulled it out b/c he has a stroker that we put in. the engine was drained then sat for about 2 months. now i swap it into my car and we can hear this LOUD knocking but its not a rod knock. sound like really fast clicking but loud.
what could it be? we cant figure it out b/c when the motor was pulled it ran great.
side note when we first tried to start it it back fired through the carb. could that mess something up?
could it be a loose roller rockers?
or do i just need to let it idle and let the oil pressure build up?
the sound is like pinging i guess(but really loud like a knocking)
any ideas?
D
ddt4436
70
  • Oct 2, 2009
A lifter may have went bad and not oiling up.
lincoln+ford
195
  • Oct 2, 2009
Im gonna guess and say you didnt prime the oil system?Check over rockers and lifters .
T
twin_turbo_mk3
31
  • Oct 2, 2009
the oil system was primed. i did have trouble turning the motor manually using the crank it seem to get stuck like it wont budge.
how would i check the lifter or the rockers?
and can a lifter go bad just by sitting?
lincoln+ford
195
  • Oct 2, 2009
The only way i can think of to check a lifter is first off see if the rockers are way out of adjustment.If so then re torque/adjust them and then if that dosent help.I would assume you have a collapsed lifter which youd have to take the intake off.
Anyone else know a better way to check this?
T
twin_turbo_mk3
31
  • Oct 2, 2009
i had a chance to check a bit more and found that i cannot move the crank manually. it feels like it just locked up. but if i crank it the starter would strugle for a mili second to try to start then it start.
if a timing chain were to jump a gear would it lock up the motor?
what would cause a motor to lock up? but when starter is used it cranks?
side note on the priming.
i was told two things.
1. use a drill and spin the oil pump shaft until the oil pressure is up.(this method for an engine that has been sitting for a while.)
2. fill oil filter halfway and crank the motor with ignition and fuel pump off untill preasure is seen.
^^ correct right? maybe i primed it wrong.
lincoln+ford
195
  • Oct 2, 2009
Prime it with the drill is the safest way that is long as you dont drop anything down there lol.
And about the cranks with starter but not by hand.
-rust in cylinder walls? how and where was the motor stored were the spark plugs still in the heads when it was stored?
Id still say pull the valve covers off and check the rockers.If anything get a video all this kind of makes me thing somethine happened to the bottum end that your budy isnt telling you.
T
twin_turbo_mk3
31
  • Oct 2, 2009
What should I Be looking for? Just torque spec?
And the engine is stores in the garage. Sparkplug was on, oil was drained out, no intake so it sat with a cloth cover. It hasn't been cold here so I doubt any rust.
And not possible I do the tune up on his car and drove it a few times before the swap. He had originally plan to use the motor but he got a stroked from another friend so he gave it to me for swapping the motor for him. And besides he wouldn't lie to me. I already got two tranny from him for upkeeping his car.
lincoln+ford
195
  • Oct 2, 2009
Check to see if the rockers have alot of play.Are the rockers stock?If so yeah re torque them.
T
twin_turbo_mk3
31
#10
  • Oct 2, 2009
  • #10
Rockers are crane cams. And no play.
Would a rod bearing cause motor to lock up? Or atleast not be able to turn manually?
T
twin_turbo_mk3
31
#11
  • Oct 5, 2009
  • #11
Well I figured it out. The new king cobra presure plate was hitting the bellhousing. guess it echo to the engine. I emailed the seller and see what's up.
Thanks for the help
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Electrical MSD Blaster TFI Coil 8227 loud Chirping Noise.
  • PonyGTrider
  • May 25, 2025
2K
Fox 5.0 Mustang Tech May 31, 2025
PonyGTrider
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
KNOCK WITH CLUTCH OUT
  • Scwhitten
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
Y
Engine 1994 Ford Mustang Gt Rod Knock/Stuck Lifter
  • yaboity
  • Jun 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 8, 2025
AeroCoupe
