  • 1994 - 1995 Specific Tech
What is this?! (pics)
  • Thread starter Thread starter MustangGT95
  • Start date Start date Sep 3, 2006
M
MustangGT95
407
  • Sep 3, 2006
I have been fighting an oil leak from my manifold. I removed the upper and stuff and I found this. It is on the block behind the lower manifold. It appears to be threaded. It was filled with oil whenever I first saw it. But it could have just been were it was running out of the intake.
Also is there a gasket for the distributor? Or just the o-ring around the shaft? Because once again one or the other is leaking from the front.
I have done many manifold installs and I'd hate to think I messed up so bad that I have the front and back leaking.
M
MustangGT95
407
  • Sep 3, 2006
It almost looks like an oil pressure sending unit hole. If so I may try to plug it. From what I can tell its definetly threaded. And at least an inch deep.
If so that would definetly explain my oil leak...and the reason for the tons of vapor I have coming from the back of the motor.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 3, 2006
  • Sep 3, 2006
Those pics are really zoomed in, Can you get some that have some reference points. Zoom out just a bit please. And they are really blurry as well.
And there is only an o-ring for the dizzy. no other seal.
Check out the o-ring that's there and make sure it's not messed up. Maybe you could use a slightly thicker o-ring if the one that's there isn't torn or cracked.
3rd pic is the hole for the dizzy, right? The top 2 are at the back of the intake, right?
Scott
M
MustangGT95
407
  • Sep 3, 2006
Yea you are right. In the top pic you can see the back of the lower intake.
If I zoom out you can't even see the whole. The whole I am looking at is behind and slightly to the left of the PCV grommet.
I believe this motor is from an f150 if that matters. It is a 302 and its roller thans about all i know lol.
MI95Cobra
451
Oklahoma City
Sep 3, 2006
  • Sep 3, 2006
its sort of looks like the pvc hose that goes from the upper intake to the back of the lower intake thats on the block...
M
MustangGT95
407
  • Sep 4, 2006
My PVC hose runs from the PCV to both large 3/8'' vac lines on the intake. Is that right? Might be why I have alittle oil in my TB.
It doesn't stick up so I don't know how it would be part of the PCV system but I may be wrong. It does look like a possible place for a oil pressure guage.
Anyone have a diagram of the PCV system routing?
S/CBlack95GT
2,018
Tampa Palms, FL
Sep 4, 2006
  • Sep 4, 2006
That hole has a bottom. It goes no where. I dont really know why it is there.
mootang
907
texas
Sep 4, 2006
  • Sep 4, 2006
that hole in the back of the block doesn't lead to anywhere, so nothing is leaking from there.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Sep 4, 2006
  • Sep 4, 2006
probably a stupid question here, but are you sure the oil isnt coming from the front and the rear where the lower intake meets the block?
M
MustangGT95
407
#10
  • Sep 4, 2006
  • #10
I'm pretty sure it is. I was just trying to rule things out because I just changed the lower intake gaskets last week.
I have done it a bunch of times and I have never had one leak. Then this time the front and back are leaking. Just trying to make sure something else isn't wrong.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Sep 4, 2006
#11
  • Sep 4, 2006
  • #11
did you use the cork that comes with the gaskets or did you use rtv?
M
MustangGT95
407
#12
  • Sep 4, 2006
  • #12
It came with blue rubber gaskets for the walls. But I did not use them. I used RTV.
I am not sure how I screwed up so bad. Maybe I didn't give the rtv enough time to setup. I was rushing. Trying to get the car finished because I hate my truck lol.
I am taking my time this time. And getting some all thread so I can make sure it goes down straight.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
