What is this?! (pics)
MustangGT95
407
I have been fighting an oil leak from my manifold. I removed the upper and stuff and I found this. It is on the block behind the lower manifold. It appears to be threaded. It was filled with oil whenever I first saw it. But it could have just been were it was running out of the intake.
Also is there a gasket for the distributor? Or just the o-ring around the shaft? Because once again one or the other is leaking from the front.
I have done many manifold installs and I'd hate to think I messed up so bad that I have the front and back leaking.
It almost looks like an oil pressure sending unit hole. If so I may try to plug it. From what I can tell its definetly threaded. And at least an inch deep.
If so that would definetly explain my oil leak...and the reason for the tons of vapor I have coming from the back of the motor.
Those pics are really zoomed in, Can you get some that have some reference points. Zoom out just a bit please. And they are really blurry as well.
And there is only an o-ring for the dizzy. no other seal.
Check out the o-ring that's there and make sure it's not messed up. Maybe you could use a slightly thicker o-ring if the one that's there isn't torn or cracked.
3rd pic is the hole for the dizzy, right? The top 2 are at the back of the intake, right?
Scott
Yea you are right. In the top pic you can see the back of the lower intake.
If I zoom out you can't even see the whole. The whole I am looking at is behind and slightly to the left of the PCV grommet.
I believe this motor is from an f150 if that matters. It is a 302 and its roller thans about all i know lol.
My PVC hose runs from the PCV to both large 3/8'' vac lines on the intake. Is that right? Might be why I have alittle oil in my TB.
It doesn't stick up so I don't know how it would be part of the PCV system but I may be wrong. It does look like a possible place for a oil pressure guage.
Anyone have a diagram of the PCV system routing?
I'm pretty sure it is. I was just trying to rule things out because I just changed the lower intake gaskets last week.
I have done it a bunch of times and I have never had one leak. Then this time the front and back are leaking. Just trying to make sure something else isn't wrong.
It came with blue rubber gaskets for the walls. But I did not use them. I used RTV.
I am not sure how I screwed up so bad. Maybe I didn't give the rtv enough time to setup. I was rushing. Trying to get the car finished because I hate my truck lol.
I am taking my time this time. And getting some all thread so I can make sure it goes down straight.
