what is this thing??
spoolin25psi
15
I have an 87 gt and i put a cage in her, n e way i took the dash out and came across a black box in the dash. If you take the plastic dash out but leave the metal fame intact it is located right above the glove box. Its got 2 wiring harness's that fo to it. Whats this box called and whats it do? :SNSign: Thanks Cody
4G-KDMP
934
CA
it sounds like your talking about the electronic fluid module, it has 2 harnesses and is just above the gloxe box.
it senses low coolant, low oil, low fuel, and washer fluid and displays them in the warning indicator on the gauge cluster.
