What is this tool used for? its old
nisreo
178
So a friend of mine inherited some old tools from a dead uncle, and in the box was this thing. I think it may be some kind of amp meter that plugs into an oscilliscope or something. Looks like it goes inline of the negative battery terminal and cable, but I may be wrong. Any ideas? He was a GM tech if that helps.
Also, you cant see it in the picture but the two wires come down through the top of the black plastic plate and are soldered to opposite ends of the bottom metal plate.
I would say it's a carbon block. You disconnect one battery cable, connect one end of the sensor to the battery, the other end to the cable, and then crank the starter. The voltage across the block is proportional to the current through it.
