  • SN95 4.6L Mustang Tech
What is wrong?
  • Thread starter Thread starter scupking
  • Start date Start date Jun 17, 2008
scupking
1,186
Enfield, CT
Jun 17, 2008
  • Jun 17, 2008
I have never been happy how my car handles from day one. So I had B springs, Bilstens, Steeda X-2 ball joints, MM caster camber plates and a bump steer put in. She still drives like crap. Sure she turns good and has a nice drop/rake to but she’s all over the road, left, right then sometimes strait, it’s so annoying. Why can't she just drive strait? I have had three alignments done and new tires put on but still no difference. I do notice that my front tires rub when I turn the wheel all the way left or right, is that suppose to happen? Anyways I'm running out of ideas of what to do to get her to drive strait. Some times when I hit a bump the front of my car wants to bounce left and right. Also if I hit a good size bump on my left side I will hear a loud thud. site I'm going to get MM full length sub frames to see what that will do.
streethorse
1,042
Dallas Texas
Jun 17, 2008
  • Jun 17, 2008
Are your sway bar end links and isolator bushings in good condition.
As for the rubbing in a full turn Im pretty sure thats not right.
Ive got 275's on 9" wheels and they have never rubbed......
scupking
1,186
Enfield, CT
Jun 17, 2008
  • Jun 17, 2008
And I only have 255/45-17s on the stock 8" wheels.
D
Dragstr05
643
Stafford VA
Jun 17, 2008
  • Jun 17, 2008
You have had 3 alignments done...but how good were they?
Also a minor detail, but the type of tire you are running can play a big part in the way your car travels on the road. I just swapped a set of Khumo's I got for free on for the summer and put my BFG KDWS's away till winter, and the difference is huge.
flstang65
1,484
135
94
SE Georgia
Jun 17, 2008
  • Jun 17, 2008
ya, directional tires will pull like a mo-fo sometimes
streethorse
1,042
Dallas Texas
Jun 17, 2008
  • Jun 17, 2008
So I guess you mean the Kumhos dont track strait.........
I have to agree with that.... I ran some Kumho ASX when I had my 99 and
they just wandered all over.
scupking
1,186
Enfield, CT
Jun 17, 2008
  • Jun 17, 2008
I have summi HRTZs, the same problem happened with my winter tires and my old all season tires.
rabidscoobie
616
12
48
College Station,TX
Jun 18, 2008
  • Jun 18, 2008
+1 on the tires.On my GT I have use Kuhmo ecsta's and BFG's,thos didnt wander on me,I honestly kinda liked the kumho as a BFG alternative for DD.But when I got this mach the dealer put Fuzion ZRi's on it and it will not drive strait without alot of effoert from me, and dont get me started on the road noise goin down the interstate on them,sounds like a 4x4 with swampers.I hate these tires,when they are gone im getting BFG's on it.
As for the rubbing im running 275/40/17 on factory stock bullits and I get no rubbing what so ever.
scupking
1,186
Enfield, CT
Jun 18, 2008
  • Jun 18, 2008
What can cause the rubbing?
04GreyGtUSAF
43
KS
Jun 18, 2008
#10
  • Jun 18, 2008
  • #10
I also had a slight rub when I turned all the way to the right. I took the wheel off and noticed the push pin for the plastic in the wheel well had come out a little cleared the noise right up.
BennyBlown2v
1,233
Carmel, INdiana
Jun 18, 2008
#11
  • Jun 18, 2008
  • #11
The problem you are feeling is BUMPSTEER! Also known as travel change, toe change, bump toe change, etc... Basically when the suspension does its job the toe in/our angle changes too much so the car pulls to one side or another randomly (sometimes depending on the crowning of the rds, etc.). Did you have the bumpsteer kit PROPERLY installed, or just shimmed up so the tie-rods are paralell to the control arm? You really need to bust out the bumpsteer gauge and have at it, it will really help, seriously!
mixedbreed02gt
Banned
Oct 6, 2007
Nashville, TN
Jun 18, 2008
#12
  • Jun 18, 2008
  • #12
i have rub on mine...I have BFGoodrich T/A KD 275/40/17's on the front, and both of mine do it, but I have to turn it all the way to get it to rub.
yep same with mine...but I haven't checked the wheel wells yet for that problem.
flstang65
1,484
135
94
SE Georgia
Jun 19, 2008
#13
  • Jun 19, 2008
  • #13
check for your rubbing on the sway bar
scupking
1,186
Enfield, CT
Jun 19, 2008
#14
  • Jun 19, 2008
  • #14
I had all the work done at Ford. I will bring her to a performcne shop and get everything checked out. This is the list I will have them do.
Front tires rub when the wheel is turned all the way left or right.
Large clunk on the front drivers side when going over a bump.
J-mod
Shift Kit
Check Gear whine
Tranny cooler
F
FullRace
41
#15
  • Jun 19, 2008
  • #15
Id say you could almost eleiminate bumpsteer on most of these cars with a simple caster change
sicK96GT
63
Austin (College in Waco)
Jun 19, 2008
#16
  • Jun 19, 2008
  • #16
I had this problem for the longest with my 1996 GT
I bought all new rims and it went away I guess the rim was slightly bend or off somehow
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • Mindseye007
  • Aug 16, 2026
Mindseye007
