What ive done so far with Codes
Oh man did I mess up
So I was talkin to my dad about the car and about the ohms thing. He told me that when I place the 2 leads (Red and black) together I should read 0 ohm. well I placed them together and they were WAY off. So please ignore the last readings I posted as I will post some new ones tonight. Thanks
Check the resistance between any of the orange/white wire connections and pin 26 on the computer.
If you do the check by probing the computer connector from the back, be sure the ignition switch is off. It may be easier to disconnect the computer connector. Loose the 10 MM bolt in the center of the connector and then you will be able to remove it.
