what kind of intake is this??
N/A no real gains.
You see big gains when used in Supercharged applications.
I would focus more on an aftermarket Plenum and Throttle body before changing out the entire manifold.
There has been a raging debate over that issue. IF your NA the stocker is just fine. If your forced induction then an aftermarket intake might be a good investment, if your using Nitrous a AL intake might be a good idea.
If you really want to change it the p51 looks good but some have had hood clearance issues and the pricetag is a little steep to me.
ponysarepretty said:
It would probably give you about 10-15 hp, considering thats about how much the Bullit gains over it. It should also more the torque curve down a bit, which is always nice.
I agree with those numbers maybe 5-10hp anyway, but either way it is questionable as to whether it is worth the cost. It does look a lot cooler though.
