HAY WHATS UP YOU GUYS, I HAD A COUPLE OF QUESTIONS. WASNT SURE TO POST IN TECH OR TALK, BUT HERE I GO
HERE IS MY SET UP
BBK LONG TUBE WITH X
GT40P HEADS
LUNATI BRACKET MASTER 2 CAM
SPECS:
Basic Operating RPM Range: 2,000-6,000 RPM
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 230 int./230 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 292
Advertised Duration: 292 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
308 BLOCK
TRICK FLOW UPPER AND LOWER INTAKE
MY FIRST QUESTION IS, WHAT KIND OF POWER WILL I BE SEEING?
AND WILL MY HEADS BE OK WITH THAT CAM, WILL IT PUT OUT GOOD POWER AT 6K RPM?
THNX IN ADVANCE FOR ALL YOUR HELP
HERE IS MY SET UP
GT40P HEADS
SPECS:
308 BLOCK
