WHAT KIND OF..........
HAY WHATS UP YOU GUYS, I HAD A COUPLE OF QUESTIONS. WASNT SURE TO POST IN TECH OR TALK, BUT HERE I GO
HERE IS MY SET UP
BBK LONG TUBE WITH X
GT40P HEADS
LUNATI BRACKET MASTER 2 CAM
SPECS:
Basic Operating RPM Range: 2,000-6,000 RPM
Intake Duration at 050 inch Lift: 230
Exhaust Duration at 050 inch Lift: 230
Duration at 050 inch Lift: 230 int./230 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 292
Advertised Duration: 292 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.512 int./0.512 exh. lift
308 BLOCK
TRICK FLOW UPPER AND LOWER INTAKE
MY FIRST QUESTION IS, WHAT KIND OF POWER WILL I BE SEEING?
AND WILL MY HEADS BE OK WITH THAT CAM, WILL IT PUT OUT GOOD POWER AT 6K RPM?
THNX IN ADVANCE FOR ALL YOUR HELP
~-Ws50's916-~ said:
SORRY, MY TEXT ON MY SCREEN IS HELLA SMALL, SO I USE CAPS LOCK... DO YOU HAVE AN ANSWER TO MY QUESTIONS BY ANY CHANCE LOL
thats a piss poor excuse.. its annoying as hell to read caps locked.
do this.
Right-click on your desktop
go to properties
click the *appearence* tab
use the FONT drop down box and make it bigger..
last step. get a good pair of glasses :p
~-Ws50's916-~ said:
It is what it is man, like i said, im sorry, can we please not talk about the CAPS now lol so can ya help by answer my question please :)
your looking at around 260-285 RWHP (i would lean on the lower end of that scale)
IMO, the cam is a little too large for gt-40p heads.. It would be better to have something a little less radical.. for everyday use anyways.
