What kinda power can a 460 ford racing crate motor hold?
fiveohGT said:
do you actually plan on a 460 swap?
100% locked in, Since june ive done the full 31 spline rear with 4.10s, TKO 600, all in preparation for the 460. I even slapped on some nitrous to hold out until I get my 460. My motor is 100% bone stock minus the nitrous and full exhaust. I didnt bother doing anything with it since I was planning to go big.
What do you guys think about doing a JY 460 block and then having it machined and stuff, just bored out and cleaned up, then doing a fully forged rotating assembly. I dont want to do a stroker.
I want to spray on the motor, so Im trying to find out what the block can take.
If you are spraying it you could build a streetable motor and still have tons of power. On the street you might be much happier with a 5500 rpm torque monster. It wouldn't break as easy.
Stock block can go .100 over and the factory crank and rods are plenty stout. Install bushings for full floated pistons and get new rod bolts.
I would find some dove-c heads and install bigger valves. Big Chevy studs screw right on those heads with frpp guideplates. The small 72cc chambers won't clatter a bit with flat tops and 240+duration @ .050 cam.
Figure your budget realistically because building one right could cost almost as much as a crate motor.
I talked to my older friends tonight (im 19 and they are 35 and older with 5.0s) and their telling me not to do a big block swap, that a small block nitrous h/c/i motor would be plenty fast.
I like to race and they say the big blocks are bad on the street for racing unless you have a mini tub (traction issues) what do you guys think?
These guys have a lot of experiance and assorted 11-10 sec mustangs, including an 11.2 sec turbo 4 cyl mustang.
Their part right,you WILL have traction issues.But with et streets or properly set up drag radials,youll hook good enouf to get out of the hole then the big block power/torque will pull from there on out.
A buget big block will go mid 11's with the right suspension tires,but then again a h/c/i 302 will too,it just all depend on how much money each would coast.
The only true disadvantage that the big block has is braking/turning.
