What knid of starter should i get?
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
Mods are listed below. im just wondering if i should get a small mini torque starter from summit or ebay, or just get a stock replacement one from advance.. im likin that lifetime warranty at advance, but didnt know if it wasnt worth the hassle of the big bulky thing. if youve had any bad / good experiences with the smaller versions, please feel free to let me know. Thanks in advance!
Stock block 302, bored & honed .030 over
Eagle Crank
Eagle Rods
TFS 10:1 Forged Pistons
TFS Stage 2 Cam
TFS Track Heat Heads (out of the box)
Scorpion 1.6 Rockers
TFS Pushrods
Melling Standard Volume Oil Pump
Double roller timing chain
Edelbrock Air Gap Intake
Holley 650 & 750 Carbs (havent decided which im using yet)
Mac 1 5/8 shorties
BBK h-pipe
Flowmaster 2 chambers and dumps
i would get the lifetime warranted stock replacement from advance and see how it does and if you don't like it or it does'nt perform proper with your setup return it for a refund. 2 bolts and 2 nuts and its removed...
I have since replaced my stocker with a 95 5.0 starter. I had to run a trigger wire from the solenoid to the starter, and move the current main wire to the battery....but it is a much better setup. My car starts much quicker than with the original, and I don't have to worry about any problems with constant power going to the starter if the solenoid dies....like it did before and burned up the old starter.
I might get a mini from the aftermarket if you will keep your old starter around (and it works - in case you need it during warranty work on the mini).
If doing local, the mini starter from the parts store would be how I'd go. The 94-95 starters sound a lot nicer than the whiny fox starter too.
My weird thoughts. Good luck.
