what mod next?
  • Thread starter Thread starter sedfhsdf
  • Start date Start date Feb 23, 2006
sedfhsdf
18
wilmington,DE
Feb 23, 2006
  • Feb 23, 2006
i am just wondering what i should do next i have something set up to put in the mass air conversion in my 87 lx but some othe people are telling me to save the $300 and put headers and roller rockers on. just wanted to know what you guyes think the best thing for the money is? also is the mass air even worth doing will i be able to get into the 12s without it?
thanks for all you help
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Feb 23, 2006
  • Feb 23, 2006
Tell us about what your car has first.... Then we can offer help. FWIW: A stockish SD car will run harder / faster than a similarly equiped MAF car. Start with the small stuff first. If the car is stock, you won't need to worry about the MAF until you go changing the cam
If it's stock and you are looking for a place to start, you can choose to follow this list:
First mods should be as follows (my take):
In order of Priority
1) Subframe connectors (SFC's) full length ones are prefered for a stiff chasis
2) Gears: 3.73:1 or 4.10:1 seem to be the popular choices
3) Full Exhuast (headers, hi-flo cats, catback +mufflers)
4) Buy a K&N panel filter (no CAI kit required) and put it in the stock box
5) Bumped timing to 12 - 14 degrees (free mod) 10 Degrees is stock.
6) Larger MAF, TB (MAF cars from 1988 california only, 1989-1993)
7) 3G alternator upgrade / electric fan
8) Fix the weak brakes
Optional MODs:
9) Strut tower brace (necessary on Convertibles IMO)
10) Underdrive pullies (they can't be used on S/C motors and cause charging problems)
11) Weight reduction out of the nose of the car
12) Shocks/Struts and lowering springs
13) C/C plates if you lower the car
14) Short throw shifter (if you have a manual transmission)
After those (the basics), it's pretty much up to you. There are plenty of Super Chargers or Heads, Cam and Intake packages to choose from.
Also, don't forget about the basic tune up
1) Changing all of the fluids (oil, coolant, trans, rear end, brake and some of the power steering)
2) Plugs: (non-platnum type) Autolite or Motorcraft are prefered
3) Oil filter: Motorcraft or equivalent (not FRAM)
4) Air filter: see first mods item #4
5) Plug wires: Ford Motorsport (FRPP) 9mm units are great
6) Cap / Rotor
7) Oxygen sensors
sedfhsdf
18
wilmington,DE
Feb 23, 2006
  • Feb 23, 2006
sorry i forgot about that stuff
I GOT
Subframe connectors
Gears: 3.73
Full Exhuast
K&N
Strut tower brace
Underdrive pullies
lowering springs
Larger front swaybar
C/C plates
Short throw shifter
Plugs: Autolite
Oil filter Motorcraft
Plug wires Ford Motorsport 9mm
MSD Cap / Rotor
new Oxygen sensors
i was just wondering if it would be better to do mass air now or do headers and roller rockers insted
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Feb 23, 2006
  • Feb 23, 2006
Ah... Looks like you have most of the list covered.
My vote is for the rockers and / or headers. Like I said before, the only thing that really requires MAF is a cam change (vacuum)
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Feb 23, 2006
  • Feb 23, 2006
I GOT
Subframe connectors
Gears: 3.73
Full Exhuast
K&N
Strut tower brace
Underdrive pullies
lowering springs
C/C plates
Short throw shifter
Plugs: Autolite
MSD Cap / Rotor
new Oxygen sensors
U say you have full exhaust but still need headers
I assume you mean you only got the h-pipe/x-pipe and catback.... right? Thats only 2/3'rds exhaust
Jaswir
578
Orlando, FL
Feb 23, 2006
  • Feb 23, 2006
maybe MSD coil, and 6al box? upper lower control arms, and then 70mm TB and intake
sedfhsdf
18
wilmington,DE
Feb 23, 2006
  • Feb 23, 2006
yea sorry i have a prochamber and flowmasters and saving up money for headers
one more question is long tubes or shorties would work best thanks for all of your help and sorr for the comfusion
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Feb 23, 2006
  • Feb 23, 2006
Just get regular shorties. There is too much to consider about installing L/T's. FRPP or Bassani ceramic's are the best.
Heat Soak
Ground Clearance
New Mid Pipe that matches the L/T's
O2 extenders
Steering shaft clearance
Harder to do clutch installs
etc....
I
IntenseBlue
946
  • Feb 23, 2006
FRPP shorties or some aftermarket lower control arms.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
I
Engine What Camshaft?
  • Iceman1998
  • Oct 5, 2024
Fox 5.0 Mustang Tech Oct 6, 2024
H
turbo advice
  • hawkinsdrag
  • May 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
hoopty5.0
