  • SN95 4.6L Mustang Tech
what mods before u supercharge?
  • Thread starter Thread starter ban-one
  • Start date Start date Dec 9, 2006
ban-one
59
ny
Dec 9, 2006
  • Dec 9, 2006
what are the basic mods u should do before u go and throw a kb or a vortech on your 99-04 gt? im looking for suspension and engine bolt ons to mae the car enjoy the forced unduction upgrade even more..
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Dec 9, 2006
  • Dec 9, 2006
3.73s, exhaust. Dont waste your time with all the bolt-ons if you're gonna go with a KB eventually. If you would go with a Centri, Id also get a plenum/TB.
If you're gonna run the car at the strip, then of course tires and suspension work, but you can always do those after the blower. After a couple of 2.3 60' times it shouldnt take long before you get pissed and order some MT's and LCA's. Id also put aside some money for 31 spline axles and a differential.
sgarlic
3,085
Dec 9, 2006
  • Dec 9, 2006
Agreed. Subframe connectors, better gears of some sort, perhaps stronger axles.. weld the torque tubes and torque boxes as instructed at MD. Stronger clutch if stick.
40th GT
916
Lawrenceville, GA
Dec 9, 2006
  • Dec 9, 2006
Agreed x2. Sticky tires, suspension work like LCAs, full-length subframes, and maybe even UCA's are a must. You also need to upgrade the rear end with 31 spline axles with a matching differential, and 3.55/3.73s.
All of this should run you about a couple grand.
40th GT
916
Lawrenceville, GA
Dec 9, 2006
  • Dec 9, 2006
deleted
CTGrey02
1,403
Bristol, CT
Dec 9, 2006
  • Dec 9, 2006
In all honesty, I think I liked the short throw shifter and subframe connectors better than the difference my blower made. I'm still on the stock clutch and it's holding fine since 2003. I have under 40,000 miles on the car. 3.27's do suck on the drag strip so make sure you get better gearing before you hit the track. As someone else mentioned, 2.3 sixty foots suck and the 3.27's will keep you there by either bogging if you launch to low or spinning if you launch to high. Nothing in the middle.
2000BLKGT
361
Toronto
Dec 10, 2006
  • Dec 10, 2006
good points above
might want to think about a brake upgrade too
not neccessarily a "before" blower mod....but you'll want one after
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Dec 10, 2006
  • Dec 10, 2006
I would recommend the exact same parts. Right now i've got the exhaust, 3.73's, and LCA's out of the way. Now i just need the TB/Plenum, some DR's, and stronger axles. Also need some LT's
I also have the upgraded brakes like someone else said. I figure if i'm gonna be able to haul ass, i might as well be able to stop safely and in a shorter distance than stock
BTW, i would add a powerpipe if its a centri and then just start saving for a built block so you can really push it
Smokeurhonda
457
Maryland
Dec 10, 2006
  • Dec 10, 2006
All above are good recommendations. I would focus on the drivetrain before anything else. Clutch, built rear, and deffinatly install subframe connectors. I would also look into welding up the torque boxes. There are only a few spot welds that hold them to the floor pan. If your making good power and can hook it you'll rip those suckers right out.
blubullett
535
Modesto, CA
Dec 10, 2006
#10
  • Dec 10, 2006
  • #10
A CLUTCH! I got a built rear end, mm lower control arms, panhard bar, upr k-member coil overs and a arms, bbk short tube headers, and a upr off road x-pipe. Put my ati procharger on it two weeks ago and and drove right through the clutch. Monday im gonna order a clutch and six speed. I love credit.
Mossberg
ATL, Shawty
Dec 10, 2006
#11
  • Dec 10, 2006
  • #11
I would focus on the best mod ever.
Get your driving skills together.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Dec 10, 2006
#12
  • Dec 10, 2006
  • #12
That was my very first mod
Built98GT
211
OKC
Dec 10, 2006
#13
  • Dec 10, 2006
  • #13
I need to do this mod next
Smokeurhonda
457
Maryland
Dec 10, 2006
#14
  • Dec 10, 2006
  • #14
WERD!
stangman
2,690
10
69
in a 3 bed, 2 bath
Dec 10, 2006
#15
  • Dec 10, 2006
  • #15
qft
the98stang
2,408
Clovis, CA
Dec 11, 2006
#16
  • Dec 11, 2006
  • #16
Before you slap on a blower you need some back up money in case something really bad happens. Like a broken rod or snapped axles. I would just save for the blower, and install it. When something breaks you can replace it.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
