What nitrous kit to get?
http://www.summitracing.com/parts/edl-70050/overview/
One of the nicest kits for the money. Designed by Steve Johnson now of Induction Solutions. These solenoids are among the best ou can buy. There plate is far better than most others out there at this price level. At the 200 hit level I would strongly recommend a separate fuel system for the nitrous along with having it properly setup and flow tested. One small mistake at this level can mean total engine destruction. Start slow and ask a lot of questions. Steel heads and a stock block = time bomb with this much nitrous..
I can't say exactly which setup jet wise is in it because the car owner wants to keep it under wraps, but if I equated it to a t shirt size it is an xxl, lol. Ill keep you posted as to the quality, dispersion, and gains vs. advertised in the next day or so when the tune gets finished up.
We dyno'd the car on motor today and setup/flowed the nitrous and everything is a go for spraying this thing tomorrow. This really is a nice kit, the plate is very well made.
Reactions: Tramage
I've had good luck with the NX stuff in the past, even the Zex works well for a good solid entry level kit.
Most guys don't want to take the time or have the knowledge to properly flow and adjust the N2O like 84 is discussing....critical for proper, safe use on a bigger hit.
For a high end kit Wilson, Induction Solutions or switzer dynamics, Fulton get my vote.
I had a Wilson Pro flow 2 stage plate kit using over 600hp very nice parts....I've since switched to boost and won't look back.
Sent from my XT907 using Tapatalk 2
Reactions: 84Ttop
