What octane
Roland69 said:
you want to run the lowest octane without detonation. any highrt of octane will be a waist of money. Do a search and you will see.
BULL. I would never run 87 in a high performance engine. Run at least 91 or better.
The higher the octane, the faster the car responds. I run a tank of 91 during the week and 100 on the weekends, and u can feel the difference in throttle response between the two. u will really notice it on a blown car.
why do u think dyno guys give u two or three tunes on a chip, one tune on 91, one on 100, and one on 114.
You obviously don't understand why they are using higher octane tunes. You don't run higher octane because you want to. :nono: As mentioned, you use the lowest octane you can without detonation.
Now, most of us opt for the higher octane fuel (93 octane) and bump up the timing until we are on the verge of pinging. Octane is only a measure of the fuel's resistance to pre-ignition/detonation. If your not putting more timing into your tune but your using a higher octane, your just increasing your pining safety margin. However, you will NOT experience power gains by increasing octane without bumping timing.
Roland is correct. Furthermore, if one is not pinging on 87 and decides to run 93 for no other reason, performance will diminish compared to how it ran on 87.
:bang: :bang: :bang: sorry I should have known better:dead:
so explain to me when my timing is not adjusted and I use 100 the throttle response is just plain better and the car runs better.
Don't run regular unleaded in a 90 GT 5.0. u will carbon up the pistons with the cheaper grade of gas.
Dude, do u know what u said here? How can performance diminish going from 87 to 93, now that is just one stupid comment!!!
Performance will increase going from 87 to 93. It is a better grade of gas, period.
yup, 304billet i think you need to do some reading so you understand how the octane ratings work. you will make more power with 93 than you would with 87, but your car should be tuned for 93 (aka more timing). If you run a lot of timing and then run 87 gas your peformance will be worse....subsequently if you run minimal timing advance (10 deg) and run 93 octane you will not see any performance gains. Yes your car may run cleaner, but it will not make more power just from switching gas, it actually may be worse.
If a car is tuned (timed) for 87 octane, running a higher octane fuel will very likely increase emissions output.
304, when I am wrong, then you can say I made a stupid comment, as rude as it saying that might be.
Good luck in your research.
Performance will not increase by simply filling up with a higher octane gasoline. It is not a better grade of gas. It just has a higher resistance to detonation and will burn slower.
Any perfomance gain that you're seeing is all in your head.
Your right, we're stupid.
This extra performance your feeling with 93 octane (the throttle response), is it proven using your "seat-of-the-pants" meter? Have it calibrated lately? :nice:
:nono: i advise that u know what ur talking about before u try to say whats best. U must not know HISSIN50 that well. he is one of the most knowledgeable guys on this forum. I would not argue with him:nice:
