What octane
  • Thread starter Thread starter billyboy1955
  • Start date Start date Feb 17, 2006
  • 3
First Prev 2 of 3 Next Last
Black1987Stang
1,422
Jersey Shore
Feb 18, 2006
#21
  • Feb 18, 2006
  • #21
blake89stang said:
i advise that u know what ur talking about before u try to say whats best. U must not know HISSIN50 that well. he is one of the most knowledgeable guys on this forum. I would not argue with him
I would do some more research about octanes and fuel before becoming so sure youre 100% right, The quicker burning the fuel the better, as long as the engine is up to it, and with my old motor i ran 13degrees of timing with 87 octane for a whole year and the pistons looked 100% normal and ran awesome...kinda like that saying or whatever, if it costs more money it must be better, in this case it's be wrong
xpeteyjtx
108
Taunton, MA
Feb 18, 2006
#22
  • Feb 18, 2006
  • #22
Correct me if I am wrong, but I think that to determine your octane, you must also take into account the ambient temperature.
For example, if its 20 degrees out, and you are running 87 octane, then summer comes along and its 90 degrees, you may have experience some pinging. In this case, your timing is probably too advanced, and in order to run 87 you must get back to the factory 10 degree timing or atleast closer to it.
I say this because I figure that when it's pretty cold out, the engine runs cooler, and so would need a more easily detonation/burning fuel, hence the lower octane.
Does my theory make sense, or am I full of ****?
304billet
315
#23
  • Feb 18, 2006
  • #23
U guys r right, I am wrong.
The reason I see a throttle response and performance gain from going from 91 to 100 is my custom chip was burned using 100 octane gas. and when I use 91, performance drops off.
HISSIN50
34
129
Feb 18, 2006
#24
  • Feb 18, 2006
  • #24
Hey, it takes a big man to admit that info posted might have been a little off. I applaud you for setting the record straight.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Feb 18, 2006
#25
  • Feb 18, 2006
  • #25
i totally agree. it not easy to admit it but if u dont they everybody wont think "he is a dumbass" most of the tme i dont admit im wrong, so that make u a bigger man then me
IWantAFox
31
SouthEast Iowa
Feb 18, 2006
#26
  • Feb 18, 2006
  • #26
You are correct except, the air density is what changes with the temperature. The colder the air, the denser the flow. That is why alot of turbos use a intercooler to cool the air to get a denser charge and prevent the hot air from detonating the air mixture prematurely. This denser charge can change your "pinging range". I use what the book calls for period. (of course my engine is pretty much stock). Oh yeah, elevation can change your octane needs too.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 18, 2006
#27
  • Feb 18, 2006
  • #27
The other thing that changes with ambient temps is the fuel additive package. In fact, in some parts of the country, the change is mandated by the EPA. So while the octane ratings may remain the same, the fuel is quite different winter to summer. The additive package changes to aid cold starting in the winter, and to help reduce emissions in the summer.
Nevertheless, you should run the lowest octane you can that will allow you to optimize your timing and resist detonation. Unless you have knock sensors to optimize timing, there is no benefit to running more octane than you need. You won't see a performance benefit; you will empty your wallet sooner; many see a slight decrease in fuel efficiency with the higher octane likely due to the fact that it's more difficult to ignite and it's burn rate is slightly slower.
I run a mild custom cam and aluminum heads with intake/exh. mods -- 16 degrees BTDC summertime/18 degrees BTDC wintertime timing. Total timing is 32 summer/34 winter. It runs on 87 octane year round with no detonation. 19-20 mpg city; 25-27 mpg highway.
bluevenom867
I will have images of molesting stuffed animals in
Dec 15, 2003
1,704
St.Petersburg,FL
Feb 18, 2006
#28
  • Feb 18, 2006
  • #28
I will say that higher octane fuel that contains lead (race fuel) do help somewhat.Its good for the valve seats for one.
And like Michael said about additives,the additive package is differant in racing fuel.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 18, 2006
#29
  • Feb 18, 2006
  • #29
Lead is completely un-necessary with the hardened valve seats all our engines run. Furthermore, lead will destroy the O2 sensors and cats in a big hurry. The only reason to run a leaded fuel is if you have an 'antique' engine without hardened valve seats. Otherwise, you should stay as far away from it as possible. It's really bad for the environment --- one of the best moves ever was the move to unleaded fuels. Just say no to lead as an additive -- un-necessary in a time when unleaded fuels can be had in just about any octane you'd need.
With near-stock compression ratios (stock bottom end), an engine in good working order, and aluminum heads -- there's little reason to run any more than 87 octane.
bluevenom867
Dec 15, 2003
1,704
St.Petersburg,FL
Feb 18, 2006
#30
  • Feb 18, 2006
  • #30
Well,I was directing that more toward the weekend-at-the-track kinda deal.Unleaded race fuel cost a bit more than the leaded stuff,and some people that mod their car dont have cats.I also dont see why 02 sensors and lead would be a big deal,so you might have to replace them now and then.But they do make 02 sensors that handle the lead.
JimBowy
330
Downriver, Mi
Feb 19, 2006
#31
  • Feb 19, 2006
  • #31
i'll be the first to say, it doesnt take long for lead to foul-up your o2 sensors... the lead literally sticks to the sensors.... not so good
D
Daggar
3,902
#32
  • Feb 19, 2006
  • #32
It should also be noted that running race fuels on cars specifically tuned for it, has other advantages aside from just it's octane rating. Octane rating (as Mike suggested) is nothing near the final word a fuel's efficiency for an intended application. It's just one factor.
Brians89GT
37
Owen Sound,Ontario
Feb 19, 2006
#33
  • Feb 19, 2006
  • #33
I always run 93 thats just what I was told to do by everyone. So I guess you guys are smarter than all my friends just cause they are still into the ricers.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Feb 19, 2006
#34
  • Feb 19, 2006
  • #34
You just answered your own ?. Ricers told you to run 93. I guess most of us are smarter than your friends cause we don't like to waist money.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 19, 2006
#35
  • Feb 19, 2006
  • #35
i like to run higher grade gas for a few tanks before a weekend drag race. this is because im going to run nos and i do not want any detonation when i am on the bottle. i have found that my car doesn't detonate on 87 octane when i am burning around town even though i have 38 degrees of timing.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 19, 2006
#36
  • Feb 19, 2006
  • #36
"I guess most of us are smarter than your friends cause we don't like to waist money."
And some of us are smarter than your friends because we know how to spell W A S T E. Your W A I S T is what gets bigger when you consume too much 93 octane B E E R.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 19, 2006
#37
  • Feb 19, 2006
  • #37
lol
D
Daggar
3,902
#38
  • Feb 19, 2006
  • #38
Some of us also make the attempt to learn something from these types of conversations as opposed to just going on to forums and running our mouth's in order to hear our brain's rattle. Do some of your own research then come back and tell us how smart your buddies are.
88SaleenClone
63
Fairfield, CA
Feb 19, 2006
#39
  • Feb 19, 2006
  • #39
I've heard that on high-mileage cars, the compression ratio can actually increase a little bit because of the carbon build-up. Is this true? I have a moderately modified '88 5.0 with 157,000 miles and I just take the middle road and go with Chevron 89 octane. Timing is at 11 degrees. Is this pretty logical?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 19, 2006
#40
  • Feb 19, 2006
  • #40
Clone - the bigger issue with carbon deposits on high mileage motors is that they can be the source of a hot spot that contributes to detonation.
What seems logical to me is to set the timing where you want it and put 87 octane in if that's what it was originally designed to run on. If you get pinging, ease the octane up. If that doesn't solve it, ease the timing down.
Amazing what can be done with technology. Just got through reading tests on new AWD sedans. The naturally aspirated engines from BMW, Infinity and Lexus were running 10.7:1, 10.3:1 and 12.0:1 compression ratios. The turbocharged 2.0L from Audi runs 10.5:1 compression ratio -- not a typo. Boosted with 10.5:1 compression. All require 93 octane fuel -- however, all have knock sensors -- so if you have to put lower octane fuel in, the computer will pull timing automatically. Power will decrease accordingly -- not because of lower octane fuel, but because the timing isn't optimal.
You can see, our 9.0:1 stock blocks with aluminum heads ought to run on 87 octane with no problems -- even with a little more timing.
  • 3
G
Octane on the 5.0 Coyote
  • gray owl
  • May 17, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 27, 2026
Bullitt347
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Engine Standard or hi flow water pump?
  • AnthonyA1234
  • Sep 28, 2026
Fox 5.0 Mustang Tech Oct 9, 2026
2000xp8
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
